  • 2 months later...
Got the wastegate actuators and fitted em up. Was a real pain to do as there is no room, but all good now.
Also got a hold of a nismo cat converter to help free up the exhaust a bit more. I'll fit it up when I can be bothered crawling under the car again.
Sway bars have been ordered in too. :P
Love the work. Was wondering what are the benefits of replacing the wastegate actuators? or is it more of a preventative measure?
I always seem to get a bit of wastegate "flutter" under light acceleration (0.2 - 0.4 bar), even worse after a cold start. and so it stutters and bogs down unless I accelerate more to bring on higher boost.
Does that make sense? It's hard to explain but that's the best way I can describe it. I've read around of people having similar problems on rexies, and some suggest tightening the actuator arm. Is that possible on our skylines?
Thanks Owen!
Only if you replace the actuators with adjustables or get some with a higher spring setting.
I replaced them to get a more stable boost at high boost settings. The standard one's tended to drop in the mid-high range of RPM.
I get the same problem, but at highway speeds in 5-6 gear at light-medium throttle up hills etc.
One fix is to weld a divider into the 'twin turbo pipe' to smooth the airflow from the two turbo outlets. I am yet to get that done.
Some say they get it tuned out?
Well, I'll be seeing you soon then Chris!! That's exactly what I want to get done.
Another piece of the puzzle done now. Got the rims I wanted to get that 'look'.
Genuine Volk CE28N 18x10.5 +18 in gold. Got 275 35 rubber on them. Next plan is to lower it 20mm.
Care to tell where you sourced the wheels from
CE28N looks the bizz too
Ya, it needs some lowering badly
Well done Sean, the car looks tuff with the wheels.
I'm kinda regretting selling them now....
You running any coilovers??
Also have you contemplated colour coding the spoiler between your bumper and lower lip?
It would give it a more aggressive look and seem like the car sits lower aswell....
Very nice car mate, credit to you......
Yep, got em off JAGR33. Wanted them wheels for a while and kept eyeing them off.
Thanks again Jack!! They are a bloody nice wheel! I will not scratch or abuse them, and I'm also going to organise center caps too.
Also importmonster seems to get in some hot wheels in every so often too. They had a different set in silver a while back, but I didn't have the dough at that time!
Still the stock Vspec coilovers, but it will get something good, in time. I have a set of HKS coilovers ready to go, but I don't want a harsh ride.
Was thinking about colour coding the mid lip but I'm still partial to the black look. I do have the paint ready to go though!
Spent a day on the GTR, fitted HKS suspension and brake deflectors. Rear seat scratched the interior trim so I'm :domokun: at myself for that, scratched pretty bad so may have to get another trim panel.
Also pulled of front lip to colour match to car so I will take pics of new stance once finished!
Yep, it's cheaper than getting discs at the moment lolz.
LH rear coilover is knocking, so that was a great buy.... :angry:
Painted the lower lip, but the paint I mixed was probably the wrong tin as it's slightly pink? I'll just take it to a painter next time I have it off.
Pics soon.
Ha ha, yeah, damn guys wanting engines built.
Hey Steve-o, looked like you got into some trouble on the day lol. When I get the car sorted I'll go. Would of loved to go, but no cash and was working on the R :) I think I like the lip painted, fills it out!
This is lowered to around 115mm on front lip, I like!!
Hey Sean
What did u do with painting.. you go the whole compressor and gun?
I know how to spray but not how to mix.. so i might require your mixing skills if i hire a booth and do a respray later in the year
That looks heaps better!! Middle lip painted white and with the coil overs makes the car look much lower to the ground.
Top job, well done.... :thumbsup:
P.s are they CSC brakes?
Thanks, I love the stance but not the ride quality. Yeah they are CSC 356mm discs with 6 pots. Need new discs though, these are stuffed. Got to find out who sells replacements.
Re spray Dave? Your car looks fine?!
I wore the sperm suit on sunday and whipped out the air compressor and my spray gun. Mixed up DG 2PAK white that I had colour matched, with hardener Added thinners but I probably didn't need to. Primed the lip then 800 sand to make it smooth, then 1 light coat, then 2 coats of the white. Nice and smooth/glossy straight out the gun. Fitted it that arvo.
I'm still learning, but I'm pretty good at painting now :thumbsup: Practiced a lot with a spray can when I didn't have a compressor and gun.
Prep work is still the most important, little things like wetting the floor etc.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
