well the 5puk sliding performance bitza clutch has let go.. well under power it has...
50,000kms 8 test n tunes 1 powercruise 1 skid pan day and its had enough haha
whats a decent clutch without going single/twin plate crap.. to support 400rwhp and drag days etc?
Edited by l0WRB
https://www.sau.com.au/forums/topic/323072-best-clutch-for-400rwhp/
  • Replies 67
true. You will have to call him. I cant remember what i paid but it was just over a grand i think. Cheaper if you have a decent clutch plate to rebuild. I warn you though he will chew your ear off.
"ill buy your bloddy clutch just as long as you shut the f**k up Jim!"
2k on a clutch that will 100% hold up for years or 1k for a clutch that might shatter itself all over the place because its on the limit.
I have a OS Giken Comp Twin plate rated at 600hp, The Nismo Copper mix one would be better for the street though imo.
OS also do a milder twin plate rated at 480hp which is cheaper.
Exedy single plate HD button....
cheap and will hold 400hp
agreed.
dispite the fact jim berry will tell you they are rubbish, i have never seen a regular pink cover exedy HD NOT do its job properly... get the early model R32 GTR one (its a lil heavier) 5 puk HD. Will be under 600 for sure.
Also, member here has had a nismo coppermix twin in his car for about 10ks, swears by it ra ra ra... I launched it once..... first non drop launch it had ever done, short hard slip at 5000rpm. say whatever you like, I know what Im doing with a clutch, it STUNK. Definately wouldnt take many of those.
Personally I buy a clutch to cop the hit and change it out more often so Im not replacing gearboxes and enginemounts every 2 weeks.
The HD button isnt too heavy and if you use it right wont smash your gearbox to pieces, also more forgiving on a short slip launch than an organic.
I put one of these said clutches in my NXR turbo 3 years ago, its still going.... who knows how many KS, how many 2nd gear slip launches... how many natio runs... how much half hour long beatings I gave it before I sold it to the noob that has it now. Still going, I see the car regularly, clutch is still holding. Same to be said about a friends S13 done in 2005.
Its a consumable in my eyes, your choice.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
