  • Replies 44
im a bit confused,
my car has 2 BOV's it has the stock one which goes back into the intake and i have a HKS SEQ as well? i have wound the boost up to 11.5psi, should i be removing the stock bov?
hey Ash
I have the same prob as u...they left my stockie on wen the put the HKS one on..
if u find out wat to do can u tell me plz :)
thanx man
SXCSKY i have the exact same setup as you! :) same place and all,
i don't know if u loose power, i think thats only if it leaks, but how do you find out?
Hey Ash...i dunno how to find out...im takin it to UAS 2day and see wat they say
Tell us if u find somethin out
cheers ;)
howdy... my skyline aint got a BOV.. but has a POD... anyways... i want a BOV on the beast and by what i have read... being a girl and all... a BOV basically could lengthen the life of ur turbo... any one object? or has reasons y i shouldn't invest in one??
u dont want Atmo bov and plumbback. coz the plumbback is known to leak over certain boost levels which will lose u boost. thats one of the reasons u upgrade to HKS or watever. as far as pressure goes, it wont make much difference since its just doubling the release of air which is good. some going back in will act like them hybrid bovs too stopping it stalling or watever coz it stil lgets air back to the AFM. but it will make the HKS quieter too probably coz not as much air coming out of it.
id remove the original i reckon. just block up the places where it goes in i.e. put blockers up any pipes that are left from it's removal. easy.
no need for 2! or yeh u could also just jam it shut somehow but easier to take it off and fill the holes with something and clamp it up nice n tight. :)
R33NismoGirl - Your car has a blow off valve standard. Has it been removed?
Ash - there is nothing really wrong with having 2 BOVs. (GTRs have 2). The factory one would have been left in place to help with maintaining the factory idle characteristics. The 2 valves will flow much better than 1 and will therefore work more effectively.
Cameron & Ash - There is a thread on these forums about modifying the stock BOV that you may find interesting.
Thats cause gtr's have 2 turbos :D hehe
yer i've herd the bov mod works good.... ?
Well I am going to disagree with a few people here then...
recently I installed a pod, K&N tapered with chrome end...have had it for about as long as they have made this model (used to be on one of my dads many drag engines) anyway it sounds awesome, good suction noise and scares the bejesus out of the od commo driver...
You CAN hear the standard bov, and it is working fine, however I have replaced the standard BOV with a GFB stealth and all I can say is giddy up...
At full plumb back it seems to hold and come on boost quicker, I am aiming to dyno to prove my point unless someone beats me to it, has already been proven on a s15...
add to this at FULL atmo the car STILL idles like factory no backfiring, no hiccups nothing, its all a matter of a bit of spring adjustment. This is only factory boost (9psi??) and I am very happy...espcially after I replaced the BOV gasket with a new one as the old one created a high pitched squel which was in fact a boost leak....
hey guys
Ok nowim confused 1 dude says its ok to have a stockie BOV with ya BLITZ BOV ...and another says seal it....and another says just switch the vacuum hose over to the BLITZ BOV .....ok guys so wat should i do then .....????? plz someone tell me way to many opinions on this subject :headspin: ....oh yeh can someone help me with the reason y i get a small backfire wen after the BOV goes off????
thanx guys :D
as far as i can see i dont have one... but i have been tol i do but it dont make noise?! i dunno i new to skylines only had it for 10 months & still learning more everyday... if someone caould give me some more info on where to find to standard BOV that would help other than that i am lost... thanx for the tips guys... i am thinking NOT 2 worry about getting one. i just got my beast back after a cracked head & head gasket lol shit happens... damn trucks!
If you have a stock airbox you won't hear the stock BOV...
i havn't got a pic to post but if you look at the pipe where the air inlet connnects to the intake manifold (near the firewall)... you'll see the stock bov with a black rubber hose coming off it.... sorry, i'm not very good at explaining but if someone can post a pic that'll show you where it is....
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
