G'day all,
I am an American who married a lovely woman from Australia last year and am in the process of visa approval. ( for the background)
I owned 1 motorhome at the time of marriage, and the wife talked me into getting a second one with the intent of giving one to a son who does diesel mechanics for a mine company, and keeping the second for ourselves. Both vehicles are LHD, :bunny: .. both will be over the 15 year past production age before the year ends. The plan is to transport them to our home in QLD. I am aware of the conversions required for the air con systems, the steam cleaning certs and safety inspections. I am under the impression I can maintain a LHD vehicle over 15 years old with the lovely caution sticker on the rear. I am looking for advice on the particulars of importing a 28" and 34" motor home to QLD. (Personally I would rather not worry with it but the little lady is determined to have them and its my duty to make it so) Any suggestions or advice is appreciated.
Roger W.
https://www.sau.com.au/forums/topic/323160-lhd-motorhomes/
Importation is a two step process here. The car has to be eligible for import (regardless of LHD or RHD) first, and then once imported, needs to comply with Australian Design Rules and state registration requirements before you can register it.
So in your case, they can be imported if they were made in or before 1988 or if you've owned them for over a year (as a personal import).
However, cars need to be 30 years old before the LHD exemption kicks in (ADR/registration requirement, not importation requirement). I'm not 100% certain on the requirements of campervans for registration, but for cars that's certainly the rule.
https://www.sau.com.au/forums/topic/323160-lhd-motorhomes/#findComment-5269114
yeah what shan said
i know you are eligable to bring them in under the personal owner import scheme but as far as lhd / rhd conversion i have absolutely no idea, and will not comment on the matter in case i give wrong info... it may be different because it's a motorhome
here at SAU we tend to deal mostly with silly low suspension japanese coupe's with big wheels
i would suggest contacting either DOTARS (google it) for further info and
...whichever queensland government department handles the roads / car registration
https://www.sau.com.au/forums/topic/323160-lhd-motorhomes/#findComment-5269308
LHD rules are actually a state thing. it varies slightly from state to state what exactly is required. check with the state department of transport body in the state in which you intend to register the car.
if you can easily satisfy the requirements of 'personal import' then I'd suggest going that way. the approval process is a little more paperwork but after that it's easier. otherwise the pre-89 rule will still suit you.
just look into the rules on LHD vehicles in the state you are moving to.
https://www.sau.com.au/forums/topic/323160-lhd-motorhomes/#findComment-5271279
  • 2 months later...
Just wondering (just out of curiosity) - wouldn't a motorhome be classed as a "truck/bus"?
I've seen some modern motorhomes that are LHD with the big warning sticker - but i'm not sure if these were just (wealthy) tourists who will then take the vehicle back home once they have finished touring Australia.
I've seen one from China/HK (chinese plates + victorian plates) - It was an Iveco brand and another from Germany (euro + tasmanian plates) - that was a Mercedes.
Off topic - I've seen an Abu Dahbi plated (no Victorian plates) LHD Ferrari cruising around Melbourne area...
https://www.sau.com.au/forums/topic/323160-lhd-motorhomes/#findComment-5419885
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
