  • Replies 40
9.5:1 - 10:1 comp pistons
spool rods
acl bearings
nitto oil pump
tomei poncams
lots of head porting + oversize valves
hypertune intake + etm exhaust manifold
nismo 740cc injectors
GT3076 0.82 external gate
3.5" exhaust from the turbo back
Tuned on E85 or 98 with a water meth injection kit.
stock motor - twin scorll 3076 with 6boost manifold and GTR plenum.... tuned on e85... responsive 350rwkw and well cheaper than a build that can blow anyway.
you would have to pop 3 motors to cover the cost of a forged build :bunny:
you would have to pop 3 motors to cover the cost of a forged build :yes:
x2
You would struggle to find someone who builds a RB better than Nissan
yeah, excellent point, wouldn't think it would be as reliable as a built motor?
money no object? lol
Tomei 2.8 kit (crank, rod, pistons)
Tomei oil pump
standard head with some baby Tomei Poncams... GTR plenum + ITB's
big baffled sump
twin: -5's or HKS 2530's
single: something in the 35XX range, twin scroll with 6 boost mani... or T04z if you like top end
how come nobody mentioned solid lifter conversion?? not worth doing??
if you were thinking of going massive cams sure, but everyone has said a mild setup so far (good response vs power made) and for that kind of engine cams like that are just going to move the power higher in the revs where you dont need/want it with that setup.
Best thing about using the 25 is the VCT... if you lose it you may as well just drop in a 26 put on a bigger turbo and rev it to 8000-9000rpm, making up for less response down low
best of both worlds: Neo head with VCT + solid lifters = bigger rev limit than 33 RB25 but with good response down low
