  • Replies 47
I cant believe no one has suggested the boost solenoid hack yet!
The ECU makes the car run less boost below 4.5k then it runs full boost after. There is a tutorial on here showing you which wire to ground so that it runs full boost at all RPMs, will give you a much bigger punch in the midrange.
Definitely give that a shot!
Have a look through the power thread mate if you want to make a set power level. If you put on even a catback and up your boost to say 12psi (safe limit for the turbo) you'll be on 160-185rwkw in an r34 gtt (depending on a bunch of stuff), so I'd imagine an r33 gtst won't be far off it.
D13 = 140rwkw (STOCK ECR33)
D14 = 9psi
171.1=D13*(D14+2)/D14
i think if the ECU was tuned properly and suitable exhaust, intercooler, intake etc
but with bog stock everything adding 2psi i dont think will give you those gains above
Is it meant to be absolute pressure mate?
I was just going to quote you here haha:
HR32 - A = 0.8 and B = 0.9 kgcm2 which is 0.85kgcm2 (average) which is 12.08 psi
BNR32 A = 0.7 and B = 0.8kgmc2 which is 0.75kgcm2 (average) which is 10.66 psi
ECR33 manual is 385mmhg which is 7.4446 psi
ECR33 auto is 270mmhg which is 5.220 psi
BCNR33 A = 0.79kgcm2 and B = 0.85kgc2m which is 0.82kgcm2 (average) which is 11.6 psi
be sure to note, that ECR33 has dual stage boost, that is the std solenoid will bleed an additional 2psi above 4500rpm
so if the std actuator according to the nissan spec manual is 5psi for AUTO R33 GTST, then at 4500rpm+ to redline, you get 7psi minimum boost
so if the std actuator according to the nissan spec manual is 5psi for MANUAL R33 GTST, then at 4500rpm+ to redline, you get 9psi minimum boost
Edited by Galois
I'm pulling 182.7RWKW from my manual R34 GT-T with just a 3" turbo-exhaust + Blitz FMIC (peaking at around 8.5psi, dropped off to 6psi by peak power) on what I've been told is a fairly conservative dyno - with a factory tune ... yeah - I was surprised too :geek:
jrm 182rwkw is about what i would expect from a car with you mods on an R34. I think willalls dyno was reading fairly true on that dyno day. my car made 327rwkw which is about what i would expect from the boost level i was running (only 20psi). People are just use to running on "happy" dynos...
I'm pulling 182.7RWKW from my manual R34 GT-T with just a 3" turbo-exhaust + Blitz FMIC (peaking at around 8.5psi, dropped off to 6psi by peak power) on what I've been told is a fairly conservative dyno - with a factory tune ... yeah - I was surprised too :P
That's high for such low boost, it seems ppl in the dyno thread need much higher boost to make that... I'm gonne get me a turbo back, this cat back is annoying lol.
What 3" system did you get?
The GReddy/Trust PE II on mine is nice and quiet for a cannon :D
I don't know what one I got to be honest... all I know is it works awesome. It sounds mean too! really raw compared to the four inch tip I had. I think I will put a resonator in still just to quieten it down a bit. It inly has a single muffler at the moment.
I think I will wait for a fuel pump before I install my boost T. Once those two are installed I might go for a dyno run.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
