Hello all,
I'm currently trying to get an engineering certificate so my R33 GTR can pass the blueslip for rego.
However, the engineer assesor wants to know if my front mount intercooler is stock, otherwise I have to get an IM240 emissions test from Penrith RTA which I'm not too keen on doing.
To me it looks very stock.
All the mounting points match up perfectly.
No logos/brands can be seen anywhere.
It looks fairly old. i.e. It's discoloured dark/greyish.
No signs of modifications to fit.
I took measurements: W:60cm x H:28cm x D:7cm
However, is there anyway of proving these are the original dimentions? Looked everywhere but need solid evidence that it's original to satisfy the engineer and give the OK.
Any help would be greatly appreicated.
Hello all,
To the best of my knowledge the R33 GTR didnt have a front mount stock, it had a side mount intercooler and I dont think it is that size either. So its probably aftermarket.
^^^ R33 GTR have stock front mount intercooler.
You can take measurments of stock FMIC and compare it. Or if you find Nissan part number (usually have U00 in the number if you know what I mean). Width and Height sounds about right, I'm not 100% on thickness though.
RTA is that pain in the arse now?
OT, Didn't you just bought this from Jamie by any chance?
Cheers
Grant
EDIT: Just checked, the thickness is 55mm so 600mm x 280mm x 55mm - this is standard FMIC.
Cheers
Grant
Fail on my part, now I know better :kiss:
Maybe try and see if you can find a brochure or something that shows the front mount in a picture otherwise I dont really know how you can convince someone otherwise, especially considering they already seem to be convinced that its aftermarket.
Edited by FrangaR33
And I've measured it after making this post.
So standard FMIC thickness is 55mm.
Cheers
Grant
Thanks for confirming that for me. Gives me somthing to work with.
Lol and yes.. I bought it off Jamie. I knew you wanted to sell yours and buy his pretty badly. Sorry you missed out on it buddy. I guess the upside is you already had a GTR where as I didnt at all :)
Definately has a FMIC standard.
What sort of proof is he asking for?
Is telling him it is stock enough for him?
I dont think verbal confirmation is good enough. My engineer is very finicky. And overall he's being very slow with the report like its a walk on the beach. I'm just trying to get sh** moving faster so I can get my car on the road finally rather than depending on him to find out all this stuff for me. It's just killing me with my mew baby sitting in the driveway doing nothing.
Also having no ends of bad luck finding any part numbers remotely close to the FMIC.
Really, if I had a specifications manual pfd or somthing, showing him that would be good enough I'm guessing. Already looked in the engine manual... Nothing in there other than how to service the car obviously.
Thanks for all the quick replies btw.
Edited by Owens
Lucky bastard.
No really, this GTR is in really good condition, good enough for me to put mine up for sale.
Well, I don't really have a GTR now - possibly broken turbo now :)
All the best with engineering certificate if all else fails, just buy standard FMIC for $150-250 and slap it on, how come you need a certificate to get it registered?
Cheers
Grant
Lucky bastard.
Well, I don't really have a GTR now - possibly broken turbo now :D
Cheers
Grant
Damn, you know I was seriously thinking of getting your car before I found Jamies. Obvious reasons aside, he seemed to have a good track record of service history, where as your's didnt mention any.
NSW laws... you need an engineering cert to go with the blueslip if you have any mods which the mechanic points out when inspecting the car.
Edited by Owens
Yeah yours have bona-fide service history which is pretty uncommon on imports. I don't have one and I only seen 2 Skylines out of numerous examples I've looked at for a while with books.
NSW laws do really suck. Here in Victoria, all you have to do is pray that the tester don't know much about EPA.
Quick and easy solution is, get standard FMIC so you don't have to do IM240 emission test - roughly a hour work swapping it.
Not really keen on spending much more money on my car since rego is gonna bite me in the ass.
Engineering Cert: ~$500
Blueslip: $80
Rego: $250
Stamp duty: ~$600
Number plates: $35
Already spent $250 on a original intake airbox to replace the air pods so I dont have to get an emissions test. That also applies to the FMIC.
Blueslip: $80
Rego: $250
Stamp duty: ~$600
Number plates: $35
Hehe, that is nothing compared what I'm facing...
I think I'll blow up to $4k to get it back on road (new turbos, gaskets and studs, service kit, PFC + tune while I'm at it...).
They're money pit alright!
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
