i am putting a rb30det in2 a 180sx and am using an rb20 crossmember and engine brackets.
what engine mounts are u all using?
i have been told that ford cortina engine mounts will make the engine sit the lowest,has any1 used these?and any idea on the part number,
i have looked in a engine mount book and there are 2sizes of cortina mounts, and its just the thickness of the rubber, 1 is 35mm and the other 45mm, a stock r32 engine mount is around 45mm.
i dont understand how using a cortine engine mount will make it sit lower when the mount bolts onto the cross member on an angle.
any info u can give would be good, i dont wanna have to get custom mounts,or drill what i have
thanks
https://www.sau.com.au/forums/topic/323248-what-engine-mounts-to-use/
