1996 Nissan Skyline R33 GTR 400R
Vehicle ID S4840
Source Current Stock
Transmission 5 speed (typo)
Kms 8,000
Colour White
Price $102,000 AUD
Status Available
1996 Nissan Skyline R33 GTR 400R, 2.8 litre coupe
6 speed
7,876 kms
White
ABS brakes
Airbags
400R factory options
All power options and airconditioning
Condition notes: Auction grade 5 A. Virtually unmarked and a true museum piece. Full personal inspection report plus additional pictures are available to serious buyers on the day of auction. But be quick as it goes up for sale early.
http://www.prestigemotorsport.com.au/modul...hp?StockID=4840
I wish i won the lotto, definatly would love a r33 like this for show :)
Edited by central coast person
………………..,-~*’`¯lllllll`*~,
…………..,-~*`lllllllllllllllllllllllllll¯`*-,
………,-~*llllllllllllllllllllllllllllllllllllllllllll*-,
……,-*llllllllllllllllllllllllllllllllllllllllllllllllllllll.\
….;*`lllllllllllllllllllllllllll,-~*~-,llllllllllllllllllll\
…..\lllllllllllllllllllllllllll/………\;;;;llllllllllll,-`~-,
…...\lllllllllllllllllllll,-*………..`~-~-,…(.(¯`*,`,
…….\llllllllllll,-~*…………………)_-\..*`*;..)
That 400R sold for more than $102,000.... we're enable to find out the exact price because it was old with negotiation with the buyer.
5 speed is not a typo
Yeah i see the sate now i was excited when i saw it not noteing the date, still awesome though! Its still 'Available' which miss led me.
Didnt mean too put that there. If you look down lower on there discription where they type the info its a typo where it says 6 speed.
BAHAHAHAHA funny :blink: i hadnt searched any Qld dealers because i live in N.S.W so yeah just back tracked a year for a few mintues there.....
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
