How do you load CDs to the hard drive and play them directly from the hard drive.
Also, What does the TA button do?
When you put a CD in, there should be a record button on the display. Press and then it will then rip the CD as you listen (store on HDD). Unfortunately i think you need to listen from start to finish (from track #1) for this to work.
Thereafter you should have another source item for your audio system (called MUSICBOX) in addition to CD, AM, FM etc.
I think the TA button is for other markets, doesnt do anything here in australia as far as i know.
thanks for the help.. have a couple of cds on their now.
So it wont copy burnt MP3 cds?
I don't know answer; would like to know too. Personally i think the whole musibox thing is a PITA and i dont bother with it. It would have been great if we have a memory card slot and it could just play from there.
my '10 has memory card slot in the armrest
but just like adding an ipod, searching through gigs worth of songs is a drainer
id rather stick with my burnt mp3 cds
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
