After cracking the brake caliper metal hose and replacing it with another one, I discovered that when I pump the brakes they feel soft. The first pump my foot always goes straight to the floor and it will go hard if continuously pumped. However if left for 10secs, the pedal goes to the floor again. I have rechecked the hose connections and no fluid seems to be leaking, and I have also topped up the brake fluid.
I read Duncan's post on bleeding the brakes and to my understanding this must be because there is air in the system (or is it something else)? If this is the case would my next step be to bleed the brakes and put in new fluid?
Cheers
Cheers
yes definatly bleed the brakes before u drive it
guaranteed you will get air in the brake lines if you have changed them.
You are going to need to bleed it a lot before it is good.....get 2x 500ml bottles.
And please be careful with brakes if you are not 100% sure you know what you are doing. Maybe get someone to give you a hand who has done it before
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
