  • Replies 191
out of curiosity, do you guys who spend big money on camera and gear do it just as a hobby/passion or are you's involved in photography as a career?
im familiar with pro-sumer types, but do you intend to eventually do it for work?
my brother is an aspiring professional photgrapher and has sunk so much money into gear it makes me wonder if its worthwhile in a fiscal sense.
Just a hobby for me (although work did pay me $200 for two photo's last year)
heres my previous photos enlarged as requested and another.
this pics just my sax with a model light pointed at it.
this shot was taken while we were setting up the lighting for a photoshoot, ending up liking this shot.
Kwinana Industrial area.
Yeah, Clint is the one teaching me a fair bit about photography. Good to see you in here finally, mate!!
I'm doing it for a hobby, even though I havent sunk too much money into my camera just yet. A fair bit is going in soon, though. Might look into doing it professionally one day, but I'm no where near that stage at the moment. In a few years, maybe.
This is a great shot, I love the subtleness and discretion but you can still tell from the lines that this is an R32 GTR. Now if you could take the number plates off... :)
I'm lucky in the fact that i have a couple of mid range lenses here at work i can borrow from time to time to try stuff with. All i've spent so far is the camera (D90), replaced a lens I dropped after some beers, and a nifty fifty. Building a house so I'm not in a position to spend up just yet, nor am i skilled enough to really reap the benefits from the gear yet. I wouldn't mind getting a good tele soon though.
I need photo guru damnnit! ;p
haha yeah the plates ended up coming off :miner:
You'll need to send me where it is Sidd, looks awesome!
Here's a couple pics I took of my mates beast after a game of footy. (SO SORE NOW.... NURSE?)
We're gonna get together and do a proper shoot sometime soon.
So ive been travelling around the states, canada and mexico the last few months...
Took some snaps last week in Cabo San Lucas Mexico.... Most beautiful place ive been!
Im no Pro, and they were taken with a waterproof Panasonic Lumix... oh and most of the pics were taken drunk too.....
Enjoy!
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
