  • Replies 191
matboy - Its in alexandria.. Oh loving those shots of the classic car :)
haysey - man so jealous!!! post up more photos ;) How long you over there for??
lepper - hahah man you really getting addicted to HDR uh? Its good tho, and not overly done. Fisheye one is great.
bnr#@ - you did a wonderful job tho ;) panning at night must be very hard.
Haha yeah, i got more shots of the pelicans. Biggest farken ones i've ever seen!
Will post up tonight. I think my SS was about 1/1600th, you can see the rain lol. Didn't even notice that before.
Bangaz Boy - Sweet photos mate!
If i were you, i would tone down on the HDR processing on your car. Everything else is fine, but especially with your car being black, reflections are killing it. Possibly use a layer mask and the original image and merge them together, with the HDR being the background and everything and the properly exposed car in the photo instead of the HDR composite.
Do you know what i mean?
Yeah mate I know what you mean :D. At the time i was going for the reflections as I wanted to see how it came up after processing it as a HDR (went a bit overboard with the processing). I've been wanting to try a few of the car with the polariser to cut down the reflections to see how it would look, unfortunately car is off the road at the moment. Otherwise I might try give the layer mask a go, really need to improve my PS skills. thanks for the tip!
I agree with kory, tone down the hdr on the car. If you've got the original pics just cut your car out and paste it over one of these. You can just adjust the tones and shadows of your car to help it blend in.
the animal shots and waterfall stuff is all fantastic mate! 10/10.
Thanks for your comments guys, I like receiving constructive criticism, trying to improve as much as possible, so feel free to give me any advice or criticism. Otherwise I'm glad to hear that you guys like some of the photos.
Barra - I know what you mean about HDR, everyone seems to be doing it these days, and there is a lot of overdone stuff (including stuff I've done). I've only recently just got my camera so I've only just got into doing the HDRs and having some fun with them. I really want to improve on standard photos instead of relying on HDR to make them standout.
Well in that case!
Cool image - might be better with bigger DoF? Not sure where I should be looking.. maybe darkening the surrounding plants and leaving middle one to be brighter
Very very flat image - needs darker darks and brighter brights (very common HDR problem due to the nature of HDRs)
Don't think the horizon is flat but it works in this image imo
That is freaking amazing. Very impressive. Just need an interesting foreground and it would be super.
Another nice one.. don't think the non level horizon works in this one though
These two are also very flat
Background slightly flat. I don't mind the HDR car but the halo's around it aren't nice
This one is perfect I think. Only thing I would do maybe is crop the bottom and left slightly.. maybe
Good shot - like the teeth
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
