  • Replies 191
ooh
when did you get some alienbees?
thats really well done sidd
every time i try to use one light like that, i always f**k it up and put it off to an angle too much and create a huge shadow on one side of their face LOL
Had it for a week and a bit now. Been meaning to buy them for more than a year.
I still havnt received half my gear yet (PLM, softbox etc). So that picture was with jsut a white umbrella. Then my stuipd cactus v4s didnt work for a bit, so couldnt use the other light. So in the end i used just one light source for 90% of the pics. But then the internal slave should have kicked in on the alien bees, but it didnt. Maybe im doing something wrong.
Anyways im in the process of building up a studio:
The backdrop is out only half way. I still got a few more meters in front.
Well still got lots to clean in the garage and make it look professional. Will get there soon :)
Testing out the beauty dish for the first time:
Will upload some more pics soon here:
http://sidd-rishi.com.au/blog/
Edited by siddr20
Nice work guys. Been sitting in a few model shoots my mates has been doing, it's pretty interesting work!
Its hard work tho. Apart from lighting, you gotta make sure the makeup, the outfits, the location is all correct. Then gotta make sure the model can pose and interact with the camera propely.
But very rewarding when you get everything right in the end.
lol YES!
there is nothing worse than awkward models and bad makeup :)
is that the actual alienbees beauty dish? or did you make that yourself?
yea who knows.. I have always used a 22 inch, even when i hired out a studio.
This was from a 22 inch: http://www.sidd-rishi.com.au/images/200910...esizeupload.jpg
Anyways i like that black n white pic you posted up above. But however now to keen ont he shadow on the side. What do you think?
So you hire a studio out?
Edited by siddr20
lol, i love how you say that with such confidence
That's because i know ;)
Well Elinchrom - 17" or 27".
Alien Bee - 22" -
Speedotron - 22" -
Kacey Enterprises - 22" -
Profoto - 20.5" - Barely anyone you meet will be using profoto unless you meet pro's (way to exxy!)
Thats about all i can remember off the top of my head.
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
