  • Replies 51
Posted Images
Hi all,
I've just got my car back after some major modifications with a healthy 272.9rwkw before 6000 rpm - obviously my crappy 235s have no chance of holding it in 1st or 2nd (barely in 3rd) so I can't get most of my power down.
The search is on for some new rears - to match the fronts i need to go 265/30/19
I was thinking of the Nitto NT05s but they don't come to Aus in this size apparently...
The two others i'm tossing up between are the Pirrelli P Zero Rosso and the Yokohama Advan AD08 - prices for these are around the $600 - $650 mark each (ouch :blink: )
Anyone have any thoughts?
Cheers.
Smokohama's....
KU36, 290rwkw, 560nm torque i believe. Great tyre :domokun: - i've got a lot of suspension work though.
Daniel (and others with them),
How do the KU36's go in the wet with that power? Also what size rim/tyre combo are you running? If it grips really well mind putting up your suspension settings up too, mainly camber etc?
I have seen the KU36 & KU31 tyres mentioned a bit lately. I thought that the KU31 might be a little bit better in the wet, only because it is not a semi-slick type design. Wear of KU36 will no doubt be a slight downfall for them.
Cheers,
Phil
Hey for what it's worth, Today I fitted 255-35 18's on my 270kw RB30 R34GTT. as long as I don't side step or flat change I can't light the tires like I could with my 235-40 18 Hankook k104's by simply rolling the power on in 2nd and 3rd gear (which cost me twice as much)
Yes it was a GTR, but was running RWD
It's all in the suspension settup
oh please share this "suspension settup' because Ive found nangkangs are a really crappy tyre for grip...
if its just down to suspension then I want to know please...
Yes if you guys that claim you can't get your xxx half decent tyre to let go on WOT could post your suspension setups that would be great! :thumbsup:
My average 235s won't hold past half throttle in 1st or 2nd in the dry with standard suspension and slightly lower springs woth 273rwkw.
Some traction issues will no doubt come from how the power is delivered. if you have a fairly even rise in torque then you won't spin them as much as there's no instantaneous jumps in boost. Mine hold on ok but with a smallish turbo it comes on fairly quickly. Someone who has a large turbo on that does nothing and then all of a sudden goes from nothing to all in the blink of an eye I'd have thought would struggle with traction? I suppose though if the suspension is set up well then maybe it's not an issue.
Well for example my R34 has the sK group buy setup ie Bilsteins, white line springs, whiteline swaybars front/rear, pineapples, rear camber/toe arms, front castor arms, front camber bush's.
I think people run way too much camber, too low, too hard. I'm really impressed with these KU31's, they were damn cheap and have blown the K104's away in sheer grip with my car any way. since fitting the KU31's I cant spin the tires by simply rolling on the throttle any more. I used to be able to do it 1st 2nd even 3rd on some rd's.
I've had K104's too and was quite disappointed in their performance after reading so many positive comments about them.
I got my Yokohama Advan Neova AD08 255/30/19s fitted to the rear yesterday.
I must say that first impressions - these are some mighty impressive tyres!
They ALMOST hold full throttle in first, letting go around when it hits peak power, 273rwkw at 5.5k rpm (ish) if I have my foot mashed. 2nd I can hold it to the floor til redline - and the shove in the back and acceleration tell me my old tyres were probably getting no more than low 220kw to the ground at best!
Even in the wet this morning they held really well and feel very very stable. But I guess they aren't cheap...! :wacko:
This is with stock suspension and lowered king springs - no camber adjustments. I'm going to get some +ve camber dialled in to try to get it to as close to zero as possible under squat and hopefully 1st will then hold...
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
