Quick question on changing a not too loud exhaust
I just brought a r33 T for a month, start considering to change the exhaust since its too loud for me (arr.. for my gf actually....)
im a newbie anyway :) so please give me some advice on this, how much does it cost in Perth if i want it quiet and also good performance (reduce sound and not restrict)
already did some search on this site but found thats not a good idea to put a silencer
(the car is pretty stock, no mod on engine/turbo)
Thanks
Edited by Bariskycord
https://www.sau.com.au/forums/topic/323340-r33-gtst-exhaust-is-too-loud/
she will get use to the noise, its prob not even that loud haha, wait till you hear my 180sx, rb20 no cat 3inch all the way then twin 2.5 inch tips.
also do you know what exhaust system you have atm, like is it straight 3inch from cat or does it have a muffler also. and how loud we are talking about here if you can explain.
but if you really have to. just do what bubba said to do, should cost a few hundred, depending if you have stainless or mild steel. not sure on what brand but i am sure the exhaust place should help you out.
there is a cheaper way but it looks funny, is putting a silencer on the tip of the cannon (if you have one)
how to tell what kind of exhaust system I got? I only found there are "genie" on the muffler ,4"
My gtr got quieter once i removed the muffler 3 1/2 inch straight through to resonator now and it is one of the quietest Lines on the road
u mean u take off the whole thing from the muffler to the resonator on mid pipe? it ll looks missing sth at the back
auctually i just want to know is that true "for t sport car, the quieter the exhaust the larger the back pressure, the greater the damage to the engine"?
i had the muffler cut out and a piece of 3 1/2 inch exhaust pipe welded in its place
get a couple hot dog mufflers welded into your exsisting system, it'l drop down the droan of the note without creating a huge restriction and in turn quiet down the rawr comming out of the end. or if you really want to quiet it down get a massive muffler put in the middle.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
