Quick question on changing a not too loud exhaust
I just brought a r33 T for a month, start considering to change the exhaust since its too loud for me (arr.. for my gf actually....)
im a newbie anyway :) so please give me some advice on this, how much does it cost in Perth if i want it quiet and also good performance (reduce sound and not restrict)
already did some search on this site but found thats not a good idea to put a silencer
(the car is pretty stock, no mod on engine/turbo)
Thanks
Edited by Bariskycord
https://www.sau.com.au/forums/topic/323340-r33-gtst-exhaust-is-too-loud/
she will get use to the noise, its prob not even that loud haha, wait till you hear my 180sx, rb20 no cat 3inch all the way then twin 2.5 inch tips.
also do you know what exhaust system you have atm, like is it straight 3inch from cat or does it have a muffler also. and how loud we are talking about here if you can explain.
but if you really have to. just do what bubba said to do, should cost a few hundred, depending if you have stainless or mild steel. not sure on what brand but i am sure the exhaust place should help you out.
there is a cheaper way but it looks funny, is putting a silencer on the tip of the cannon (if you have one)
how to tell what kind of exhaust system I got? I only found there are "genie" on the muffler ,4"
My gtr got quieter once i removed the muffler 3 1/2 inch straight through to resonator now and it is one of the quietest Lines on the road
u mean u take off the whole thing from the muffler to the resonator on mid pipe? it ll looks missing sth at the back
auctually i just want to know is that true "for t sport car, the quieter the exhaust the larger the back pressure, the greater the damage to the engine"?
i had the muffler cut out and a piece of 3 1/2 inch exhaust pipe welded in its place
get a couple hot dog mufflers welded into your exsisting system, it'l drop down the droan of the note without creating a huge restriction and in turn quiet down the rawr comming out of the end. or if you really want to quiet it down get a massive muffler put in the middle.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
