Cube wheel options
60 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 114
I really like the CE28N looking rims in the middle of the last set on Mukyboy's pics (the maroon car) .... or the Meisters - (possibly get them mirror polished all over) - would look tuff on a black Cube!
Agreed!!!!
I'm likin the VIP style. Lets face it the thing isn't gonna be fast (thats what the EVO and 34 are for :blink:) so why not bling it up a bit?
If you don't mind spending up, Fabulous do wheels ('Profound' I think is the rim style) in pretty much any size/offset you could ever want.
vs-xx if you can find em in sizes small enough. (im not bias or anything :blink:)
otherwise meshies. get em polished then get the cube slammed with a bit of camber... would look hot as on a black car.
Edited by SkyHi_33
I don't know many sets of Panasport F1s in Australia :)
Maybe I'll get the Meisters, paint them black and get [NVMYCUBE] on the plates....
meisters, yes.
those plates though...
i agreed on the maroon car :)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
