Cube wheel options
60 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 114
what are these 15" and 16" things you talk of? How do you spell that? "W... E... A... K"?
18+ or GTFO. Your car is gonna stand out like a midget in purple pantaloons, do yourself a favour and make sure your wheels are just as outrageous.
lol It was the Sportmaxx 501s that I originally ordered (16x8 +15s...), but after waiting 2 months and being told I needed to wait another 6 weeks by the Aussie "supplier" apparently due to a second stuff up in the order from the warehouse in the US, I told him he could stick it and give me my money back. Feel free to PM me for the name of the company.
The problem I had with going too small is the massive radius of the guard lip, it tends to make smaller wheels look like shopping trolley wheels, regardless of how wide they are. The only solution with smaller diameters is to dump it stupidly low, which then makes it too impractical for every day use.
I ended up buying the white Meisters, which despite being 7" width (bear in mind the factory alloy is 5.5", the steelies are 5") should be cherry ripe for the offset. Now to hunt down a factory strip kit in white to match...
UGLY?
I really think you need to have another look,. modular one piece forged wheels extremely lightweight as used on some rather tasty European cars. Here is an example of an Audi R8 and a R35 GTR.
Edited by Adelaideprosound
Actually, while I have your attention for a moment, have you ever seen leather (MSpec) R34GTR seats come up at the auctions? Do you know a rough price I would be looking at?
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
