Hello all,
So im currently waiting for my Power FC to arrive, once thats installed how much power should I expect to make at all 4s running 14psi with 98 octane unleaded and the following mods:
- 3.5 inch exhaust from the dump pipes back
- pod filters
- Walbro 255 pump
- sard fuel reg
- power fc
- 115x300x600 I/C
Im hoping around 250awkw?
https://www.sau.com.au/forums/topic/323348-how-much-power-can-i-expect-to-make/
Sell the fuel regulator and pod filters (if you still have the standard airbox - unless you want to sell it to me) - not needed at all.
240-250awkw sounds about right.
The reg and the filters were on there when I bought it, so cbf taking them off unless I really need to??
Currently has a mines ecu, how much do you think that is worth second hand?
You can make that power but might need a little more boost. Waste of money to change the stock intercooler tho, they're fine for 350kw. I ran my stock turbos at that boost and they lasted a couple of years before they blew up...
Yeh, forgot to mention you don't need a/m intercooler.
In nutshell, the following modifications needed for 240-250rwkw are;
Power FC (or aftermarket ECU) and tune
Dump back exhaust at least 3"
Removing boost restrictor 'bung' - instant 14psi without boost controller
Good quality panel filter in standard airbox
These are all you needed.
Easy,
Yeah I didnt think the A/M IC was needed, but other than the power FC and pump, everything else was on the car when I bought It.
It has a fibreglass copy of the original front bar, so I can only assume the front was crashed at some stage, hence the change of intercooler and front bar...
Hello all,
- pod filters
- Walbro 255 pump
- sard fuel reg
- power fc
- 115x300x600 I/C
You can compare your mods to other RB26 owners to also give you an idea.
- http://www.skylinesaustralia.com/forums/Rb...yno-t93880.html
:blink:
Hello all,
- pod filters
- Walbro 255 pump
- sard fuel reg
- power fc
- 115x300x600 I/C
find a good tuner and make sure those pod filters are shielded from the rest of the engine bay otherwise it ll just be sucking in huge amounts of burning hot air, reduce response and power.
important note, double check the SARD fuel reg is real, there are a lot of fakes on the market and would you hate to have a cheap chinese fuel reg managing your fuel pressure. fakes are known for giving unpredictable fuel pressures.
Edited by Peter89
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
