I dont think cheap is the way to go as from experience you end up spending more on repairs to keep it on the road. Your better off spending 8k mark the money you spend now you will save if you had got a older car + your driving a newer car around you get me?
As above mitsubish magna 6 there cheap and tough as nails, just stay away from a Bombodore or a Fraud.
  • 3 weeks later...
  • Replies 81
If you go a magna go for the TJ2 models, 2002 onwards. They're a good improvement over the TJ model.
Auto magnas have a weak point in the gearbox that will go if the car hasn't been serviced regularly/has done large amounts of towing without a trans cooler/or if you're unlucky etc... The 3.5 v6 magnas are not bad to drive, plenty of torque to pull you along, but like most cars do have their issues.
Also worth considering is a similar year camry. I have a 2000 3.0L camry and a 2000 3.5L magna, the magna is more fun to drive, but the camry feels much more solid even though it has over 50k km more on the clock.
Maxima and accord are also worth a look at.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
