you can use an R33 GTR strut brace you just have to put the bolt holes through the strut tower as they dont come with them from factory same place as the S2 R33's have them bolt on thats what i have bought to put on my 4 door either way will add another point to the towers so will see if it makes a difference when i put mine on i am sure that it will help
Cusco used to do them, you find them on yahoo auctions every now and again, as said above not sure if it'll be benefitial. Otherwise they seem hard to find.
EDIT
found one:
http://page22.auctions.yahoo.co.jp/jp/auction/l37040651
Edited by ltcree
  • 3 weeks later...
please consider using punctuation in your long winded and confusing replies because just linking everything together like this makes it a pain in the arse to read and also turns any answer you give into the babble of a noob which removes any credibility you may be trying to obtain cheers
Yeah no don't put a rear strut brace on the r33. I learned this after the fact. Get swaybars instead. Much better handling mod.
