Does anyone have a regular workshop they go to on the northern beaches? Good service + reasonable rates?
Before last week i assumed Joviant Performance was worthy of a visit. Enquiring about an uprated Walbro fuel pump supplied/fitted. The owner told me $300 for the pump and.......... $300 to fit!!!! Dodgy bastard told me they'll have to completely remove the tank and its not an easy job. Thanks but no thanks!
Then went to Magic Performance around the corner which told me it was a 10min job.. Been there a few times and they're very helpful and HONEST!
Is there any other tuners on the NB that deserve a mention?
Cheers!
https://www.sau.com.au/forums/topic/32338-northern-beaches-workshops/
I've been trying to find a decent workshop in the NB. There isnt any! But these are the ones I've found to be well respected by many Silvia clubs. (first preferrance to last)
Autosport Engineering @ Kirrawee
Advan @ Silverwater
ProConcept @ West Ryde
Corydon @ Silverwater
I've been going to Envy Imports for the last 2 years and have been more than happy with their service and prices.
I've had both major and minor services done there during this period, the latest being this week when I had a major service.
I've also had some mods done to the car including:
front mount intercooler
fuel pump
fuel regulator
electronic boost controler
clutch
adj cam sprocket
2 turbos
bonnet pins
+ more
Give Herman a call on 9907-4144 and tell him Mark sent you.
www.envyimports.com.au
The workshop is located near my old high school (freshwater high) in Harbord.
Let me know how you go.
I haven't been to Joviant because they quoted me way too much to buy and fit a BOV.
Another place is in Dee Why near Cromer High school called Procar.
I've been there twice and on both occasions it was to tune my powerFC (they have a dyno).
MRK25T: I have seen and been informed of several issues faced by friends at workshops around that area and frankly after visiting several I simply cant say I would be prepared to have any work on my car. I am extremely picky and careful when choosing a workshop.
My opinion and my judgement.
Where in Sydney would you take your car/ or where would you recommend friend go for work on their cars?
I would not let any workshop on the northern beaches touch my skyline. I have heard horrible stories from some of the workshops on the northern beaches, I have also seen the workshops and think that they are no where up to scratch with staff or quality equiptment.
If you want a good workshop I would say go to CRD, UAS or C&V. I have had work done by CRD and UAS and could not be happier.
Thats it Carlo ! :(
Special this week - B-Man's port and polish job with worn out angle grider bought from Super Cheap Auto for $16.95 :)
Stop whoring this thread B-Man.
Are you talking to yourself again ??
Yes
Oh, OK !
Shut up
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
