Where Can I Bring My Gtr To? Problems Arising...
Hi guys
So my car is starting to do a slow and steady death in terms of driveability.
I don't know if it's the clutch slipping or some other unearthed problem. Sometimes the car doesn't rev or pick up speed like it should. It feels like I'm pulling a two tonne truck at the back, revving it freely is fine. More to do with trying to pick up speed in 2nd gear. On full launch, 4-5krpm, the car revs but doesnt seem to transfer the power to the drive train. after a few seconds or so, then only it'll kick in.
sometimes it'll rev at a, 3krpm, and speed will remain constant then only pick up.
Anyway, without trying to 2nd guess too much, anyone know who I can bring my car in to have a look at it? preferably near the Preston (northish cbd) area.
Thanks!
Thanks guys
Yea I ordered an Exedy HD from Dan @ modyourcar, no dosh for a twin plate at the moment, this came unexpectedly. Also ordered new seals and a nismo pivot ball from Kudos, since they'll be under there.
Will be taking it to some Clutch/Brake specialist up the road *cross fingers*
My car is my life at the moment, I can't do anything without it.
Racepace are good but are mighty costly
Racepace mate, they specialise in GTR's and are a little pricey but do awesome work.
they're very well priced in my opinion. you basically get what you pay for its really that simple.
I agree mate, they are very well price for the work they do I just meant that they might be a bit pricey compared to some other places around. I'm one of their customers and honestly I couldn't be happier, i'v never had any issues with their work, prices or service, it's always awesome.
that doesn't sound like clutch, if it was clutch revs would increase dramatically with no rise in KPH
This does sound like clutch though, so I guess you are doing the right thing by changing it but it may be something else. Only one way to find out I suppose :sick:
  • 3 weeks later...
Just to update, brought my car to Darby's and he did a TOP JOB.
Didn't actually have to swap my clutch, but he put in all the parts I got.
New clutch, new seals, nismo pivot joint, brake and clutch flush.
When he stripped everything down, he found a problem with my servo. Apparently the bearings were smashed, hence causing the clutch not to bite at times. This was the root cause of the "slippage".
After $1.2k, I'm a happy camper. Not so happy when the credit card bill comes.
if your launching at 4500rpm is a single HD strong enough? perhaps twin plate would have been better
ie baby it around until you can afford tiwn place. would be ashame to see you fry this one in a short time and have to replace again
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
