Hi,
selling my r33 gtst series2 silver manual coupe
straight clean car, work done by racepace, oil and filter every 5k kms
the cars on carsales hope the link works, in brief:
fmic
turbo timer
18'' wheels
alarm/immoboliser
cd player
rwc and reg till october
$11,700ono
feel free to pm me or grab my mobile off the ad, thanks
http://www.carsales.com.au/all-cars/privat...6&silo=1011
https://www.sau.com.au/forums/topic/323405-r33-gtst2/
Hi dude, thank for the email, i didnt see any pics.. but ive narrowed down a short list as it is, had a lot of replies and organised some inspections now. Thanks anyway, if you do have any pics be nice to see them but i think ive got it nailed.
Cheers dude.
https://www.sau.com.au/forums/topic/323405-r33-gtst2/#findComment-5355487
After further thought, am going to do a WTB for a similar sydney car, if nothing suitable by the weekend, I will call to talk the sphincter of the universe.
Assume you have no problem with me arranging an inspection on it if we go further?
Steely
https://www.sau.com.au/forums/topic/323405-r33-gtst2/#findComment-5367906
  • 4 weeks later...
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
