In the last few days, every time I go over even slightly bumpy surfaces the rear-end moves slighlty sideways.- like it does when you loose traction in the wet. This is occuring even on dry roads.
The tyres are not worn.
Have I worn out/ broken something??
It's getting a little scary to drive now.
Thx
Oz.
https://www.sau.com.au/forums/topic/32341-rearend-sliding-out/
Sounds like you've done something nasty to your suspension.
I Had the same problem last month-the problem was my left rear shocker. It had leaked out all it's oil over the previous couple of days. Nice big oil blot on the driveway under the left wheel the next morning.
I would check the rear shockies and lower control arm bushes and this would cause excessive rear movement and thus cause the "sliding" you are referring to.
It sounds more like a shock as the active rear end in a skyline is less susceptical to thsi problem in relation to worn or broken bushes...
Easiest thing is to take of your rear wheels and inspect shocks for oil leak.
My car came from japan with a slight oil leak in the rear left shocker... exactly the same symptons... i suggest u get it replaced soon.. i had a very interesting incident where I was driving in a straight line at 200k+ and hit a bump and the rear just jumped out.
DAMN scary.. lucky I was on a private track!
