i want a kakimoto mega n1 system formmy gtr
i found a second hand system from a r34 gts t, will this fit the 33 gtr? if not will it need allot of mods to fit?
what about r32 and r34 gtr system, are they compatible with r33 gtr?
has anyone out there used the ballistic cat from sureflow exhaust? are they better than the magic cat?
https://www.sau.com.au/forums/topic/323458-finding-an-exhaust-for-my-33-gtr/
as far as i know none of the exhausts are interchangable really manly to do with different lengths an turns an bends... my friend got his exhaust done today on a R33 GTR V SPEC with a 100 cell metal cat 3inch mandrel tig weld an cannon at the back for $1050 sounds very nice....
I can get tailor made systems at a good price. I found a kakimoro for a good price so that's why I want to try and fit it.
So does anyone know how diffirent they are? If it's only the mount points that are diffirent then I will go for it. If I have to chop up the pipes then I won't buy the kaki..
Do they even do R34 gtst's?????
this is a cut and pste from the ad
hey i have here for sale a kakimoto/jasma mega n1 exhaust system for r32 gtr/gts-t, 3.5 inch, 2 peace cat back system
woops. i just relised it says 32 gts t not 34
so do you think this system will fit?
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
