alternator has been like this for a year now It works but i find if i park and leave the reds on or im listeniing to music for lets say 30min-1hr i have new battery dry cell type. But i find that when i start the car and drive with the air con for instance im looking at the battery power and its at 12.2 v and i take my foot off accelerate it drops to 11.9 and i get a warning beep from the turbo timer it eventually rises to normal level i think around 12.7-12.9v but i think my alternator might be on its way out i heard it should sit stable at around 13v, and i should b able to have the music on for more then 2 hrs right before battery drains??? can i get a recoditioned alternator or get mine recond? and how much am i looking at?
https://www.sau.com.au/forums/topic/323480-94-r32-gtr-alternator/
Actually this morning as im driving it was at 13.3 v stable i put the air con on and it dropped too 13v-13.2 it just goes up and down a few point depending, see if the lights are on stereo are on etc, it will be at around 12.8 is this normal?
Your alternator should be working between 13.8v to 14.3v to maintain the electrical load.
Sounds like the voltage regulator is on its way out.
Once the engine is running the battery is "not " running the electrical items. The alternator is meant to carry the entire electrcal load. It will replace the charge to the battery after startup or draw from the battery if electrical items were used while the engine wasn't running, but once battery is charged the alternator just delivers enough current to manage the load.
What is the part number of your alt. Is it a Hitachi or Mitsi branded model.
I rebuild them from home, "may" have some suitable parts
Nigel
Nigel
Is it visible from the engine bay? and what costs am i looking at?
GTRAAH, this happens to me as well. No matter how I drive, the voltage meter on my turbo timer won't go past 12.6-12.7, only time it ever goes past 13.0 is right after I cold start it then after a minute or so it drops back down to 12.6 again. Also if I leave the car parked for too long (eg. 2-3 weeks) without cranking it then my battery runs flat. If I listen to music for around 20mins without the car running then battery goes flat again. I've replaced the alternator twice already and have had to buy new batteries numerous times in the 4 and a half years I've owned it. The car's had this problem ever since day one and it's slowly driving me insane! :cool:
Edited by GT32
Yeah there should be a label on it on the back/side area. Some are underneath. Might have to use a small mirror to spot it.
Cost depends on the alt model.
Also the part number will telle what amp the alt is.
You may need to use a 90amp model
Nigel
Nigel, when I replaced my alternators I've always bought one off an RB20DET motor. However, I run an RB30E bottom end. Are the alternators across the entire RB-series of engines all rated at different amperage? Should I be using an alternator that was taken off an RB30 as opposed to one off an RB20? I've always wondered if that would make any difference in my circumstance...
Edited by GT32
Some R31 Skyline RB20DET (red top engine) came with a 70amp. R32 RB20DETs should all have a 80amp. Then there is the 90amp used on R33's RB25 etc.
The thing is just because an alt came off a RB20DET engine doesn't mean it was the factory unit. Alt could have been swapped out at some stage.
In most cases the 70amp is fine unless you running some high power draw items, eg. big amp sounds etc. The 80 and 90 amp units will just cope better with the load.
You certainly do not have to match the alt to you RB30 block. But what I would suggest is getting the alt with the smaller pulley (69mm instead of the 73mm). That way the alt will be spun slightly faster. The alt in question would be the Nissan 23100-70T05 (Hitachi LR190-722) 90amp. It has the 8mm BAT bolt versus the 6mm on most others. Still a direct swap on all RB engines. You will just need to change the eyelet on the cable for the BAT terminal to 8mm.
I know of 17 different alternator factory fitted from R31 to R33 Skyline etc. Some made by Hitachi and others Mitsi. The odd Bosch on in Australia.
http://www4.wave.co.nz/~lakewood/Skyline/Alt.htm
Nigel
Nigel
Nigel where you at mate if your in sydney i might come for a drive so you can have a quick look at it?
Hehehe sorry mate. I'm in Hamilton, New Zealand. If you can take some pics though and send them to [email protected]
Nigel
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
