hey guys,
got a few things for sale in order to pay for a new built engine coming through....
- VQ35 engine out of my 03 350z.... SOLD!!!!!
- 350z HALTECH PLATNIUM PRO ECU (comes with computer, harness, reciept, warranty)
RRP: around $2600, asking $2100
used for around 2000kms
must sell ASAP to afford new built engine funds
check out the specs on this great and easy programmable ecu
http://www2.haltech.com.au/index.php...d=91&Itemid=78
- standard NON-BREMBO brakes also off my 03 350z w/ plenty of meat left on pads.... includes 4 calipers, 4 rotors, lines etc $500
- standard clutch w/ heaps of meat left $150
- stndard 17" oem wheels with bridgestone tyres
(60% 225 front, 55% 235 rear)
little gutter rash, one rim has slight surface damage $450
- BRAND NEW vacuum gauge with all equipment necessary $50
- 2 sets of aftermraket gandor mirrors (both with l.e.d indicators)
have a black set, and also a gandor set sprayed in standard lemans sunset colour
black pair - $60
gandor lemans sunset mirrors - $100
Please PM me or contact me on 0402 839 768
or by email
[email protected]
Thank you
pete
also have a BRAND NEW:
2 piece 4 ply silicon radiator hose kit
no ugly name tags etc on them
blue in colour... $50
or $60 express shipped anywhere in australia
p.s. these are made custom for the vq35 for 350z/v35
  • 3 weeks later...
    • Get a timing light on it and verify it's sparking reliably at a sane ignition timing. Use a COP extension lead to be 100% sure about timing instead of hoping that the timing loop on the back of the engine is accurate. Make sure it's actually injecting fuel. MAF is not used on the stock ECUs for initial cranking.
    • RE5R01A is the transmission. Didn't realize they had a 5 speed for the NA cars but for some reason the turbo engines stuck to 4 speeds. Looks like the solenoid block is still available from Nissan directly at a somewhat reasonable price: 31940-60X01 https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/er33/6568-rb25de/trans/317 I would move sooner on this than later. The moment the de minimis exception for Japan goes away expect to be paying 25% tariffs even for stuff like this.
    • Only RB26 are low from factory. And even then the ECU actually want high impedance, because it's essentially the same ECU as the RB20 anyway, and thus they have a f**king resistor pack!
    • Is this preventable by priming the system with external oil pressure? I've seen the speed academy folks hook up an external oil priming system to the oil pressure sensor port with an air compressor to check for oil leaks before putting an engine back in a car. Something like this: https://www.jegs.com/i/JEGS/555/23550/10002/-1?gPromoCode=SPRINGINTOSPEED_APR25_5Off&gQT=1
