Rb26 Engine, Aftermarket Injectors, Fuel Rail, Turbos, Clutch, Cams, Gears, Etc.
Hey guys.
All this gear is in A1 condition, was all destined for my s14 drift car, however motivation is lacking big time and money is always alot nicer than parts sitting around!
Ok so here is the general jist of the parts.
R33 RB26, 160psi across all 6 cylinders, gold rocker covers, motor is complete with all hang ons, including AC pump, sump, diff, etc. Had all intentions of putting it in, have pulled the sump off and motor is dead clean inside, all inspections and tests welcome. Comes with turbos which have been rebuilt with N1 spec cores and have heat treated rear housings, however it looks like one of these may have had a slight rear seal oil leak. Wasn't noticeable when car was running, only when I pulled front pipe off (3" jap pipe, will include), tiny amount of oil in the rear dump pipe(stock dump pipes). Comes with Full engine loom, NEW factory coilpacks, no standard injectors or rail, has AFM's with HKS air filters attached, no ecu as was running power fc which has been sold (I was going to run my motec)
Also have, Siemens injectors, unsure 100% of size, powerfc was set to 60% on injector duty, so that leads me to believe they are at least 600cc, PFI top feed twin entry fuel rail, anodised purple, shiny, -6 fittings.
JUN cams, 260in 270ex 9.25 lift, with tomei cam gears, great condition, are not in motor, came out of another motor from japan, and I bought with intention of using them, however they will not suit my RB25.
HKS triple plate clutch, clutch is near new, heaps of meat left on it, PUSH type. Hub centre style clutch.
Prices:
Motor complete with hangons, turbos, loom, coilpacks, etc $3800
Injectors + Rail $650
Cams + Gears $850
Clutch $1800
Phone: 0427282562
Note: All parts can be sent interstate, I work for a SAU sponsor and have had no issues with sending large parts out previously and I'm sure my works trader rating would speak for itself. All parts are verified to be in a good working order, and were removed from a running track only GTR less than 1 month ago. (cams were purchased separately however are also in good condition)
 Share
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
