in every gear, around 4000 rpm on full throtle my skyline is hesitating, if i release the throttle a little it kicks back in and starts increasing rpm again, i changed the plugs and taped the coil packs done a diagnostic and had it on the dyno, diagnostic was clear and the dyno said everything was fine. any help? i also cleaned the pod and afm
i am running standard boost, front mount, fpr no other mods
https://www.sau.com.au/forums/topic/323521-loss-acceleration-in-high-rpm/
the coils could still be breaking down a bit, even if they are taped. the only way to know for sure would be to try some coils that you know are good.
also there is always a slight flat spot around 4500rpm due to the vct switching there
