  • Replies 85
Ok, So since the helmet that I use (Thanks Paul) still has Green Wang pump racing on it. I think the team will have to be re-united.. Hopefully Scotty won't burn out the clutch this time.. :laugh:))))))
Team Green Wang Pump Racing FTW...
as maka reported, the dust has been blown off the green wang pump and i just tested it out... shes a beut!
looking at the total lack of trash talking happening here, i can see there is a total lack of team honor and that can only spell TGWP dominance.
Mike... youll need to drop more than 20kg of that super structure to make any difference... i think i saw the making of mike on the discovery channel "engineering marvels"
Bard... i know you can drive... but... with poor team selection, one can only challenge your decision making skills so clearly your mind wont be there on race day
Paul... now your a dad you will likely have a baby seat strapped to the back of your kart and a "baby on board" sticker so i expect to pass you on a regular basis as you chug around the track at "school zone speed" taking notes of hoon drivers to complain about
Tom... just crash
Scott McKickass
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
    • Toasty! I was around the same. Around 50 but with a fuel cooler. Got my tuner to dial down the pumps and its so much better.. i think last time I drove it was around 35-40 during summer. PWM makes a huge diff. I have the 1 PWM controller running my feeds.
    • Driving around town in summer, probably like 50°C tops. Went for a 2 hour drive before in summer, somewhere in the 60°C Mind you, I have 3x fuel pumps. 2x 460L 1x DW200
    • Good advice, I’ll try that.  and yeah i thought 5 degrees was a lot as well. The gates T291RB timing belt that was recommended for this engine was kinda tight when installing it and with both cams inline with the timing marks, the belt teeth wouldn’t line up with the gear. So I just turned the whole exhaust cam gear like half a tooth so the belt would go on and then adjusted the cam back inline with the timing mark, so some of that 5 degrees is from that. The actual cam has probably only changed about 2-3 degrees if that makes any sense lol also wouldn’t stuff like decking material from the block, head and different thickness of headgasket and the fact that it’s a rb30 bottom end affect the accuracy of the original timing marks?
    • Hows your fuel temps? I had big issues with fuel temps running 2 285's.
