Missfire Boost@4500-5500 RPM - The Answer! (for me at least!)
hey ben, i have noticed that you have mentioned a 10rwkw gain on your car from just the spitfires, its a bit hard for me to believe, so could you please explain the circumstances
ie. if there was a dyno run directly before and after u fitted them on the same dyno or whatever..??
(i just expect my car to run properly again when i put mine in!)
Hey mate, relax with the CAPS :)
i taped plastic pieces between the coils and the frame as a last resort, this lessened the misfiring, but as the car got hotter it was pretty much the same as before, and oh yeah, the plastic started melting  :rofl:
that was my last resort, so yesterday i just ordered a set of spitfires. ($$)
Sorry it didn't work out for you, it does get hot in there.... so far my plastic hasn't melted at all, but the amalgamated tape has deteriorated a bit, but still covering the coils pretty much. Thecar has done 500kms since in various temps, and so far good, no misfire at all.
I think that the method described in this thread is an excellent fix for the relative cost (<$1), but at the end of the day, splitfires are the go.
Do you mind me asking what you paid for your coils?
Or if anybody reads this, where is the cheapest? for new blue splitfires?
The best i've found is $900.
all i got to say is CHAMPION i have spent almost a year trying to track down this interrmittent miss bought a set of coils from SSS and spent hours changing one at a time trying to find the one that was stuffed Got home last night spent half hour taping all 6 coils and then went for a test run and beautiful no more miss also this morning sweet as to work so Thanks for helping with my ongoing headache
Hey,
i paid 635 delivered from sau trader newkon.biz..
but i believe he has updated the thread with info that he has no more stock, so i guess you could ask him when he is getting more, he gets them from japan direct not from the aus distributor, which is why they are cheap.
the cheapest i have seen locally is around 900 as well.
i have had the spitfires in for a week now, they work fine, back to full power and maybe a little more :P
Its good to see your fix is still holding up! i guess mine had gone too far already, and it was not one, but three of them that were stuffed!
having a very similar problem, tried tape, lessened the problem but not fixed..... Ordered coils from nengun, they were $560 (delivered to queensland) on special. (they arent a great deal more off special) very good service from these guys........
just a thought, something that might be a more perminate fix could be glued heat shrink
tho im not sure were you would get it from and how long it would last.
i am going to try and get some from work and ill let you know how it goes.
by the way thanks for the tip with the tape... so far so good. *touches wood*
Here is a more permanant fix:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=51046
I did this over 9 months ago and haven't had to touch them again....
If you do it properly it is a permanent fix....
Alternatively you can do like i have and that is fit 6 Bosch coils (MEC717)and run leads
Changing plugs is a piece of cake now. and you can use the standard ignitor
This is working on a Series 1 RB25 so external ignitor not sure about series 2 with the built in ignitor
What did that cost if you don't mind me asking....
I was exploring this alternative ages ago, but found it expensive at the time, so I was going to go for the splitfire replacements.... before I gued them...
Anyhow, if it is a cheaper alternative to splitfires, then it may be the go for many others...
Complete price for 6 coils and leads was $300.00 as to labour cost my mate is a Auto Electrician so it did not cost me anything for fitting and wiring
But as a Example a Workshop wanted $600. to supply and fit a set of VN commodore coils.
Apparently a guy over in NZ has found a Buick V6 coil pack that works fine, and for $150 I am about to find out if it is or not, just about to order one.
http://forums.skylinesdownunder.co.nz/show...&threadid=39596
Hi guys
I have had this prob for some time as well . just went into jaycars and bought "starbrite liquid electrical tape " it says its got a service range of -30 degrees to +255
let u know what happens
Hi Guys,
I just taped up my coils with electrical PVC tape and that seems to have cleared most of the misfiring ie, runs pretty decently.
However, I notice that when I'm crusing in 4th gear and then decide to give it some, the engines sometimes cuts off and then all of sudden goes good. If I were to slow down and then accelerate immediately after this happens, it doesnt cut off anymore.. Could be that I have missed a coil?
Any help would be great... and lastly please let us know how that liquid electrical thing goes..
thanks
steve
seems to work ok you have to rally coat after coat to build it up in the "danger" areas along the sides. I dont think its the answer. this week im going to fit a set of vs-vr coils .anyone using the vn ones (they are square as apposed to the vs-vr ones that are round) should realise most holden guys swap to the later ones cos the early ones are so much trouble
we will have to see how it goes. the coils are around $150 from the wrekers.
and if you are aseries two you need an igniter (the little heatsinked aluminium box that sits at the back of the rocker cover) as im series one its easier just pull the wiring that usually goes to the coils join them in three lots of twon ( the right ones that is) and a few connecters
if it works well its got to be the best answeras the coils are out in the airflow then. and if you are worried they wont perform as well you can always spend 3x $108 for motec ones for holden 3.8's at autobarn
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
