Missfire Boost@4500-5500 RPM - The Answer! (for me at least!)
I can't get to my plugs because I can't disconnect the the loom plug. I can't get it off and I don't want to break anything!
There is a clip on the top, but do you push it down or lever it up? Either way I still can't disconnect the stupid thing! :)
  • 2 months later...
I went to Sydney to look at a few 99 R34 V Spec GTR's with a mate today he picked one out and we took her for a 'test drive'.
The car started fine idled fine, didnt blow smoke, wasn't running rich when cold, everything seemed great.
We hopped in went for a spin and from 2-4k rpm in any gear when cruising. It was coughing and farting like a $200 TX gemini running on sugared unleaded, but when giving it a squirt & hitting boost at 4k rpm the misfiring disapeared & it pulled nice and hard to 7-8k rpm.
Most cars that I have either heard of having misfiring occurs when the car hits boost at 4-5k rpm on a hot day, but this thing as soon as it hit boost smoothed out and pulled hard to redline in 1-2nd gear and idle smoothly also...
The car looks to have a genuine 25000 kays (its in mint condition) and just has minimal mods (pod filters, hks exhaust from the turbo) as far as we are aware its running stock boost, stock turbos and a stock ecu.
Obviously the car has been sitting around for 6 months or maybe more, and may just need a new fuel filter plugs and a new tank of juice.
Could a fuel pump cause this problem? coilpacks? timing? loose i/c hose clamps?
The car is booked for a full checkup on Wed, but it would be good to hear if any other forum members have had similiar problems?
Edited by DR-JEKL
ok so just taped every coil, the problem is a shit load less prevelant, but it is only backfiring in 1st gear when i turn right, this is the only time it has done it and only gear, i just spent the last 2 hours out there testing and fiddling!???
wat the heck does this mean?lol
i had this problem and i originally had 1.1mm gap so just the standard gap for this plug then i gapped them down to 0.75mm it removed my problem for a while however now upgraded to a slightly larger problem has caused the same problem so im getting splitfire coil packs cant go wrong with them :-D
  • 4 weeks later...
this problem has been truly giving me the shits for a long time in the 33.
I originally dropped in BCPR7ES sparkys gapped at .8; it slightly solved the problem. You could still feel a bit of loss in power above 4000rpm.
After i installed a FMIC, in the cold weather shes boosting around 12psi, and the missfiring is a hell of a lot worse.
i'm going to try this coil pack taping over the weekend and post the results...
If i can truly nail it down as the coil packs being the problem, next investment for the car = splitfires
Carried out the work today and took the 33 for a drive; no more miss! Fantastic!
a couple of the coils had scorch marks and even minor plastic melt. definitely time for a new set
  • 1 month later...
Hey guys, just thought i would say great post. Very informative and usefull. I sugest people read the whole thread first before they post a question though, as alot of them were already answered before the new post was made. Anyway as i see it maybe some actual pictures would help people get a better idea.
I have recently bought a R33 from the importers, it had a miss when trying to run boost any higher than stock. I changed the plugs they looked like the original units from the factory lol but then u expect platnium plugs to last 80-100k and mine had 90k on the clock. Anyway changed plugs with good quality NGK platniums 1.1mm. Still had the miss but i changed the plugs at night and never got a good look at the coil packs. After reading this thread i pulled them out, every coilpack had arcing scorch marks on the sides and i araldited them all see attached pics before and after.
post-19941-1222408610_thumb.jpg post-19941-1222408833_thumb.jpg post-19941-1222408908_thumb.jpg
So far so good, pulls hard through to redline without any misses @ 0.85 Bar (12.3psi) big improvement and i didn't have to regap my plugs as im hesitant to do that. would rather a dyno tune once i get my dump and front pipe on and my front mount intercooler happening. get my A/F mixture right and it should help the stock coils alot.
Don't underestimate Aryldite, i once used it to patch up a bolt sized whole in the magnesium alloy engine casing on a Honda XL 250 motorbike. Last i heard it lasted 10years without any problems and still going strong :-D yay for bodgy backyarders ROFL (jk i plan on geting splitfires when my exhaust and frontmount intercooler are on)
  • 1 month later...
Hi guys
just wondering if i could grab some advice, i have the same problem in my R34 now i have pulled out my coils and they are perfect no cracks or anything like that, taped them up just incase, now i was wondering could it be the ignighter in one of the coils that could be causing me problems ? it also back fires pretty loud sometimes between gear changes ? :(
Another cause can be the car running way too rich, this will exasperate the cracked or worn out coils. I've heard of people having this problem with f**ked coils and then getting a re-map from 10:1 to 12:1 and the problem going away.
Edited by Rolls
  • 3 weeks later...
Hi i have a r34 and for some reason it goes into somthing like a limp mode where its only firing on 3 or 4 cylinders , Ive just replaced oxy sensor and plugs and 2 coil pack have been repalced ive cleaned the air flow meter aswell . Could it still be the coil packs ? I so run out of ideas . Because Its happening twice a day on the way to work and then on the way home. I used to be able to restart the car 4 times and it would be ok but now that doesnt help. The only other thing that happens is my slip light comes on and trac control light and the engine light and abs aswell. I went to the auto elec and he pluged his computer in and came up with a error 21 ? dont know what that means . Can somone please help.
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
