Nightman Posted January 18, 2004 Share Posted January 18, 2004 I *HAD* a miss in my R33 GTST when the air was cold out side or I put the boost up high. This happened at around 5000 RPM, after many months of chainging plugs, coils etc, I finally know what is wrong and a fix (not sure how long the fix lasts!)... (the reason it does it more when the air is cold is the Boost was higher due to more dense air) Note: All Coils tested FINE with a multi meter - This is not a valid test for this problem! after a really really good examination of the coils it seems that there were lots of scorch marks and some other really small marks, which looked like the spark was jumping from the case of the coil!!! Looking VERY closely, I found that all bar 1 of my coils have a hairline (almost invisible) crack on the front of the coil! (I will post a decent picture later): ~~~ --| <--- Ignition Plug ~~~~~~~~~~ ~~~~~~~~~~~~ ~~~~~~~~~~~~ ~~~~~~~~~~ <--- Crack Here! Top to Bottom and on Some, Into Plug Tube ~~~~~~~~~~ ~~ ~~ <--- Spark Plug Connection ~~ (Sorry about my Crappy ASCII Picture!) What I did was tape the lower half of the coil. ~~~ --| <--- Ignition Plug ~~~~~~~~~~ ~~~~~~~~~~~~ ~~~~~~~~~~~~ ~~~~~~~~~~ <--- Tape here ~~~~~~~~~~ ~~ ~~ <--- All the way to here ~~ I no-longer have a miss!!... I put the boost up even more then before, and still no miss!! - this morning was nice and cool outside on the way to work - still no miss!!! Anyone having problems with missing, just tape the coils you already have, use a REALLY good Stretchy Electrical tape... not the 25c crap you can buy (this was useless!) - I will have to try and find some high temp non-conductive glue and try it some time too! Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/ Share on other sites More sharing options...
Nightman Posted January 18, 2004 Author Share Posted January 18, 2004 Grrr.... My ASCII picure got mangled!!! Bascically, under the 1 cm metal thingy, tape it up all the way around (3-5 Layers) and continue down the boot for the plug about 2.5 cm or so Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-649027 Share on other sites More sharing options...
tenzero Posted January 19, 2004 Share Posted January 19, 2004 Nice work in solving this problem mate. I have a very similar problem and will try it out. Was the electrical tape you used just pvc electrical tape? or the rubber tape from 3m that can be streched about 50% and is not sticky like normal tape?? Cheers. D. Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-650468 Share on other sites More sharing options...
sewid Posted January 19, 2004 Share Posted January 19, 2004 To make ASCII pics look nice, use the tags Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-650607 Share on other sites More sharing options...
Guest Robo's Posted January 19, 2004 Share Posted January 19, 2004 Safc Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-650691 Share on other sites More sharing options...
Nightman Posted January 19, 2004 Author Share Posted January 19, 2004 tenzero: PVC Tape, but a good brand one. - Theres just some really crappy tape that does not stick... and because the coil is tapered, its hard to make it stick... sewid: Code tags made it better but still not 100% When I find a Dig. Camera I will take some shots Waiting for the work camera to come back! Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-650707 Share on other sites More sharing options...
Nightman Posted January 20, 2004 Author Share Posted January 20, 2004 sewid: I got it... Thanks mate! Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-650712 Share on other sites More sharing options...
JimX Posted January 20, 2004 Share Posted January 20, 2004 Well it looks like you've already helped 2 people solve this problem. Does anyone know how they crack to begin with though? Is it just heat that stresses them out? Might be worthwhile setting up some sort of ventillation for the centre cover, especially in summer. Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-650829 Share on other sites More sharing options...
Nightman Posted January 20, 2004 Author Share Posted January 20, 2004 JimX: Judging from mine, I'd say it was Definatally heat related... years being closed in - I think plastic has gotta go sometime! Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-650858 Share on other sites More sharing options...
Zahos Posted January 20, 2004 Share Posted January 20, 2004 Safc EXACTLY! Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-651163 Share on other sites More sharing options...
Nightman Posted January 20, 2004 Author Share Posted January 20, 2004 How is a safc gonna fix faulty coils? sure, it might mask the problem by changing the fuel ratio so as the spark is easier to make, but the problem will still be there and eventually get worse and catch up to ya! IMO Anyways... Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-652178 Share on other sites More sharing options...
dAVE Posted January 21, 2004 Share Posted January 21, 2004 if the tape doesnt hold and you need coils, pm me good work tho.. should help fix a fair few ppls little misses. dave Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-652324 Share on other sites More sharing options...
Zahos Posted January 21, 2004 Share Posted January 21, 2004 How is a safc gonna fix faulty coils?sure, it might mask the problem by changing the fuel ratio so as the spark is easier to make, but the problem will still be there and eventually get worse and catch up to ya! IMO Anyways... Sorry, I guess you mis understood. The problem with boosted R33's is that they run mega rich, and the ignition maps go all over the place, so you will definately get a misfire, or loss in power at the 5000rpm range with standard management. A SAFC corrects this problem. Once the A/F are laned out, the ignition maps start to look better, and you won't see this problem. It looks like with cracked coils the problem is more evident. I dunno if my coils are cracked, but ever since the SAFC was installed, it has run like a dream. I'll have a look at my coils anyhow, coz the misfire I used to get was quite shocking.... Anyhow, good work on that discovery, but what I'm trying to say is that the problem goes much deeper than that... Some form of aftermarket management is definately needed on any modded R33! Zahos Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-652384 Share on other sites More sharing options...
Nightman Posted January 21, 2004 Author Share Posted January 21, 2004 Zahos: Ahh, yes. If you boost up you can expect things like that (ECU goes into Safe mode - FILLER UP! )... But, I also *USED* to get a miss under normal boost in cold weather... Changing the Plug gap made it slightly better only! Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-652503 Share on other sites More sharing options...
Zahos Posted January 21, 2004 Share Posted January 21, 2004 Zahos: Ahh, yes. If you boost up you can expect things like that (ECU goes into Safe mode - FILLER UP! )... But, I also *USED* to get a miss under normal boost in cold weather... Changing the Plug gap made it slightly better only! Ahhhh -> "normal boost" You're first post implied this, but coz I'm so used to hearing about misfire @ > stock boost, I guess I missed it.... Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-652569 Share on other sites More sharing options...
Nightman Posted January 21, 2004 Author Share Posted January 21, 2004 Hehe, Yeah thats my next step! > BOOOST >>>> but I wanted to fix my Miss under NORMAL boost first! ... Now... Who's got a cheap safc for sale?! Seriously... ! Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-652574 Share on other sites More sharing options...
Cecam Posted January 22, 2004 Share Posted January 22, 2004 The coils get pretty hot under that cover and probably overheat, for an R33 S2 just remove the cover, for series 1 I used one of the ignitor bolts into one of the cover bolt holes to keep that still, and same for R32's (remembering they have earth wires on the ignitor, R33's are down by the coil brackets). Appears to help some cars... sure it looks abit more ugly but the coils ain't frying anymore... Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-654955 Share on other sites More sharing options...
bless_you Posted January 25, 2004 Share Posted January 25, 2004 yeah, safc fixed my prob too Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-658772 Share on other sites More sharing options...
ABuSD Posted January 30, 2004 Share Posted January 30, 2004 Hey fellas i have an SAFC and i think i may have the same problem!! And ive just had it tuned also (by a very respected tuner) Thing is he tuned my car on a 27degree day and it gets worse when the weather gets colder! Maybe its not a miss?? I also get a pop out of my zorst in between gear changes is that related?? Cheers Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-665217 Share on other sites More sharing options...
Abo Bob Posted January 30, 2004 Share Posted January 30, 2004 Just thought I'd let you all know. My issue turned out to be the Crank Angle Sensor. I tried new plugs, then new coils (luckily had an identical car nearby that worked) but Crank Angle Sensor it turned out to be! My car is an r34 GTT btw. Link to comment https://www.sau.com.au/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/#findComment-665228 Share on other sites More sharing options...
