Missfire Boost@4500-5500 RPM - The Answer! (for me at least!)
just put in the iriway 7 spark plugs, still the same, im all out of ideas, i inspected the coilpacks so many times, no burn marks or melting or loose components etc.
any ideas people?
Can a blocked fuel filter result in the car missing/spluttering as described?
If it is totally blocked it could cause it to run very lean and misfire, it is fairly uncommon though.
Edited by Rolls
I had my engine rebuilt for my 32 GTR a few years ago and after the run in I found I wasn't making full boost and was braking down. I found my stock IC plumbing was piping off and then re sealing (took me a while to find that one) then it ran good for a few years and then for a while I had a problem of it breaking down under boost, poping and farting, miss firing like a mofo!! I spent almost every few months changing spark plugs and checking AFM's IC piping. Then I decided to buy new coil packs. Oh man what a difference!!! Red-lining holding boost no worries now. Went with the splitfire. Best investment!
  • 3 weeks later...
As always the trusty skylines community has helped resolve my missfire issue..
Symptom:
Got a service completed, engine bay cleaned and car started to develop a missfire under load through the rev range starting at 2,500 - 3,500 then 4,500 - 5,500.. Sounds like a machine gun popping..
Swapped out spark plugs which appeared to be quite old and coil pack completely failed when placed back.
Resolution:
Looked at a number of posts and ended up buying a set of 6 yellowjackets rather then splitfires from Performance Wise, arrived in 3 days - great service from Paul..
Put them in, car is performing as normal, no missfire!
Note: Car would idle fine and would be ok when gradually coming onto boost, only when wide open throttle and under load would it missfire..
http://www.performance-wise.com
  • 6 months later...
Symptom:
Resolution:
That sounds exactly like my issue, but mine isnt that severe, just jerky when wide open trottle under load. I will try my mates coilpacks and hopefully that fixes the issue.
Cheers mate
Have a RB25DET with stock coilpacks. Always had a miss fire on idle even with copper or iridium plugs. Car made 291rwhp on stock turbo.
Then I got a GT3082, car makes a 351rwhp. But it has a horrendous missfire on full load, boost @18psi.
So I took my coilpacks out to silicone/tape them. And saw #6's coilpack and plug were burnt out. Thoughts?
Where is that coil plugged in? :sick:
  • 4 weeks later...
Anyone tried these coil packs: http://www.ebay.com.au/itm/Performance-Coil-Packs-RB20-RB25-RB26-R32-R33-GTR-/110462393656
Chasing an intermittent miss and wouldn't mind ruling out the coil packs but $600 on the Spitfire ones seems like overkill (fairly stock R32 GT-R).
They look like Superspark knockoffs. Try yellow jackets: http://www.ebay.com.au/itm/YELLOW-JACKETS-COIL-PACKS-SKYLINE-R32-RB20DET-S1-R33-RB25DET-GTST-GTR-RB26DETT-/170868197763?pt=AU_Car_Parts_Accessories&hash=item27c889c983
I bought mine off performance wise around 3.5 yrs ago and they are still going as strong as the day I installed them. Neva skipped a spark:)
You can also get them from their website for a little cheaper - http://performance-wise.com/userimages/procart28.htm
Why didn't I read this this morning? Had my coils out chasing a break down in ignition and found my plugs were gapped really badly. Also I don't think the plugs had ever been changed going by how tight all the bolts were including spark plugs.
My 34 was running around 13psi on standard everything but when reved hard would go "b b b b b b" does this sound like coil breakdown or miss firing? It's an auto and it's previously only ever done right before changing gear but was doing it all day Sunday.
Edited by RSFOURDayz
Thanks for the tip. I'll look into the Yellow Jackets (although trying the cheap ones is tempting).
Edited by BuuBox
  • 3 weeks later...
  • 5 months later...
missfiring, had the same issues, checked the coil, taped it, replaced sparkies, all good
dont forget to check the coil plugs
  • 7 months later...
that sound just like the problem I've got with my r33 on closer look also found we were getting a voltage drop
at alternator replacing with RH9 hyper Alternator 130A have been told we could be putting to much load on
alternator with extra electronics, will try your fix for coils tho before ordering new coils
  • 5 weeks later...
Hows it goin guys
Im new to this forum had for a while haven't been on it as much
I got a few questions if any one can help...
I duno whether i have a boost leak or not
my 32 gtst is spitting some times black smoke
and i always have low revs
some time when break car will switch off
and last night went out car switch off never came back on
thought it was the batt
but narhh
i think it may or may not be the plugs
i got a general understanding on motors ut not 100 percent
dnt want to do something to make it worse...
if anyone can help...
    • Isn't this what everyone immediately sees in their mind's eye when someone gives them a total width number and an offset?
    • It won't be this - not while it's driving, anyway.
    • when does it run badly; hot/cold/both, idle/part throttle/full throttle what computer is running it and what data can you get from it?
    • Perhaps, and it's deceptively similar. I was yesterday days old when I first heard anyone mention that the default guards have exactly XXXmm space. No more "is 8.5+37 going to be flush/fit, or will it poke? how much? 9.5 +16.9?" etc. Can just do maths and subtract from 100 - Shit, Wheels should have this measurement stamped on them. "This wheel extends 74mm from the hub in one direction and 57mm in the other" This is a far better system than offset, inches, and backspacing.
    • Hi guys, I know I lt could be a range of issues although when driving my gtr its starts sputtering and stalling feels like maybe an inter cooler pipe loose or so but that's not the case. recently had a comp check with 165psi across all 6 give or take a few psi. a mate was saying maybe IAC valve  could anyone point me in the direction of where to go from next I was thinking coils / plugs.   its due for an upgrade so I'm going to r35 coils. In the mean time I'm Just wanting to get it running alright    cheers
