Missfire Boost@4500-5500 RPM - The Answer! (for me at least!)
Hi guys how much do new coil pack generally cost for R33s, and where is a good place to get them with not getting ripped off. Thanks
i have this same prob. i am not mechanically handy.. as in i dont do work on my car unless its really simple. i dont think i could do all this removing on the coils. does anyone know where i can get this fixed? how much are new coils?
It really is very easy to do, im no garage mechanic myself (normally restricted to just oil/brake pads) but even I managed to get in there and work it out. The only problem I have is not owning the correct tools so I only took 1 out to see how it all works and then put it all back together again.
I think a workshop could do the whole thing in 30mins.
Did this today while i had my plugs out to regap them, cant say i had a problem before but i did it anyway..
I ran the car on .95bar tonite on the highway and no problems all the way to redline, not a single miss, hesitation... nothing.
I recently put Trust VSPL intercooler kit, AVCR and Trust Catch can on.
I couldnt run over 8psi with the above setup, but after regapping plugs to 0.7 from 1.1 and taping the coil packs, it runs 13psi like a dream.
I think this is something everyone should do, it has all benefits and no disadvantages.
Oh, and cheers niteman :) I doubt anyone would of ever have figured this out, but u definately did stumble upon something good.
Props to you!
Well the funny thing is i did find a common crack on about 3 coil packs, the crack wasnt across it was down, about 1cm long on one of them
But the thing is, Ive never had a problem with missing or anything anyway.
So its weird, but i taped them up anyway. And can confidently say that it helped towards me boosting 0.95bar without a single problem, i dont use this boost all the time, i just did it to see how it goes, i now cruise on 10psi and its perfect
I taped it pretty professionally too, if you tape around, then tape across you can use the different angles to hold each other on.. if you know what i mean.
So in reality, its not a temporary fix because the coil isnt broken.
I was quoted between $420 and $500 for a full set of six good condition, second hand coils, though I managed to find a full set for $300. Will whack them in tomorrow and experience full throttle goodness once again :D
Long story short;
On saturday I taped all 6 coils and my miss is gone however it feels slightly 'flat' on 12psi from 4500rpm onwards although it's been a while since I last gave it a flogging on a 'working' 12psi so it may actually be back to normal.
I never drive my car on 12psi except at the drags (which won't be happening for a while) so that will give me time to permanently fix the problem.
I have a feeling its #1 + #4 that's causing me problems. The #1 coil looked like the only 1 that may have had a hair-line crack on it and #4 I taped up last and my car definitely drove better when it was taped compared to when it wasn't.
What options are their for aftermarket coils and at what price?
Mine went really well for about 5 mins, then it ****ing started missing again. I was getting all excited too, it starting barking up at the top of second (which I haven't been able to do since the problem first started) and then I headed for the highway... by the time I got there, the problem was as bad as before. Damn.
I'm investigating aftermarket coils too. Splitfires retail for $1095 iirc, but I've seen them advertised for $950, so with some more digging and haggling, you should be able to score a set for $800. Maybe. I'll be checking for leaks in the intake piping (already have but I'll go over it with a fine-tooth comb) and also for gaskets that are marginal etc. I'll also be doing things like making sure that the coils are earthed correctly, though I'm not sure that will work, given that it worked fine for a bit and then stopped working. I know that PC's don't work as well when they get hot (as in, up to operating temp, not melting point), are coils affected the same way?
Is it possible to run both standard + aftermarket coils? I mean at $1000 for new coils i'd rather grab some 2nd hand 1's for between $50ea to $200 a set and just deal with the problem again in another 50,000km than shell out $1000 just to be able to use 12psi for 2mins per month which is what I currently do.
  • 3 weeks later...
Guest Slide
I have same prob but mine does it about a hundred times really quickly at anything over standard 7psi boost
at least 10/20 pops per second its that fast and that often that as soon as i go over half a bar boost when set at 12psi it pops.
i created a new thread moments before i stumbled onto this one here it is.
Somebody help me!!!!!!!!!!!!!!!!
I have taken my R33 to a number of stupid so called specialists and they have all given me different answers which have cost me nearly $2000.
On standard boost (7psi) it runs like new ,Anything over (i mean even 1 psi over) it pops not detonates. it sounds like it is backfiring.
it looses boost and it sounds like it is just feeding it out the exhaust. verrrry embarassing.
sound like it is farting. I am using a turbosmart dual stage boost controller (tried a different 1 already) 750hp fuel pump, ngk irridium plugs,fuel lines, injectors have been cleaned ,3'' turbo back exhaust, pod filter ect. I have tried tripping the computer did not fix.
Help Help Help (eeeger to run more boooost) i feel like popeye without spinach
http://www.skylinesaustralia.com/forums/sh...ead.php?t=47752
I havent tried taping yet will do but by the sound of it ,it only happens a couple of times
maybe mine is different. i have tried 50000km worn coil packs and still no go
Dave '
just been to tuners and have now got missfire around 17 lb boost and around 5-6 000 rpm, didn,t have this before , tuner says a coil has decided to break down , do you have any other ideas or a set of good coils i can buy please.
Kind regards
dave :)
if the tape doesnt hold and you need coils, pm me :(
good work tho.. should help fix a fair few ppls little misses.
dave
Dave '
Kind regards
dave :)
If the tuner said a coil has decided to break down, get him to tell you which one. Buy/borrow a known working coil and replace it yourself, and if the problem isn't any better then get yourself a new tuner.
Guest Robo's
You have tried everything, have you got a SAFC??? Sounds like its overfueling. You have the same problem as i had, put a SAFC in and lean it off or if youve got plenty of $$$, get a Power Fc and get it tuned. That will fix it.
taped up coils..... lol
I wonder how long that will last for :) Good on ya KIWI ingenuity!
last time I had a punchure I tried chewing gum on the hole, lasted for a wee while...hubba bubba i think was the brand :D
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
