HI guys, great forums here!
I have just bought a '93 R33 GTS-T, and want to replace the skinny stock tyres on it with some decent rubber.
I am considering 235/45 on 17s at the front (on 8" rims), and 255/40 on 17s at the rear (on 9" rims).
My two biggest concerns are that if I go with the general consensus and 235/45/R17 on the front and 255/40/R17 on the rear I will
A) get a pretty harsh ride and
B) Get into grief trying to do a hard launch or powerslide with 'diff bounce' (not the right term, but all I can think of now).
At the moment the stock tyres allow me to do fantastic, smooth powerslides and launches without the wheels bouncing up and down like crazy and costing me time (and perhaps killing the diff)... what is the likelehood of having that problem with 255/40's on the rear?
If it occurs, do I need to go to a higher profile/skinnier tyre to avoid it, or buy better shocks, or is it as the guys at BobJane suggested down the the choice of tyre (not size)?
What do the drifters use on these things, these sort of tyre setup? I dont plan to drift, but certainly want to be able to step it sideways or do a serious launch.
Any help would be appreciated! Thanks
Conrad
I have exactly the tyre/wheel sizes that you want to upgrade to, and I only have 2 problems - 1 is the guards are too narrow on the front, I need to get them rolled or something (or buy GTR guards :D) and 2 the rear tyres are so soft they shred and leave black tyre dust all over the back of my car. Well that's not related to the size at all but I thought I'd mention it anyway :D
I don't have any problems with comfort, handling or traction with this setup. I'd say a lot of that would have to do with your shock absorbers and sway bars anyway.
Hi JimX,
thanks for the update - do you run stock suspension on yours? mine is totally stock at the moment, so trying to get a feel for if I will need to move to better shocks once I have this tyre setup on.
Hmm... if theres no probs with the sizes I have picked, now I just have to pick WHAT tyres to use... sheesh!
I do like the look of the Falken 451's, if you have any advice on tyres I am listening :D
I've got Bilstein shocks in mine. It did have the factory suspension when I got it but it was totally worn out so I can't really compare the ride qualities. The steering wheel would shudder like a bastard everytime I hit a decent bump with both front wheels at the same time.
I've heard that the Japanese sports suspension (Cusco/JIC/Tein etc) are all really hard and not very comfortable for Australian roads. And unless the road is really smooth you'll be airborne a lot of the time anyway with ultra-hard suspension. I was originally after Koni adjustables but apparently they don't do a kit for Skylines yet.
For tyres I would probably go Nankang, that's what I have on the front and they seem to be a bit harder than my rear Toyo's (much less tyre dust) but seem to grip just as good. When my rears wear out I'll try Nankangs on the back too. I don't know much about Falkens because they have so many different models, but I do know that the low-end hard model that most people put on their Skylines to compliance them are pretty crap. Go for something a bit softer.
Check out this thread on tyres
Tyres
I have the 25540s on the back, and 23540s on the front, its an awesome setup, and doesnt ride harsh at all, with the purchase of my new tyres i'll have a similar setup.. try and keep the profile the same.. is there any reason you want 45s on the front and 40s on the rear?
235/45 is a closer match in height to 255/40 than 235/40 to 255/40. Here's what the profile height of each of the aforementioned will be:
235/40: 94
235/45: 105.75
255/40: 102
255/45: 114.75
So if you kept the same 40 profile front to rear, the rear tyre diameter is 8mm bigger than the front as opposed to about 4mm smaller if you got 45 for the front. I guess it's not much difference either way, but for that reason it's fine do choose either profile combination.
Personally I would get whatever size made the speedo most accurate (ie closest to stock) and then get the profile on the front that was the closest in size to the rear.
The reason why i say it would be a little bit harsher would be
the less flex in the tyre wall on a lower profile tyre.
Does everyone agree or disagree with my theory/practise?
Hmm. but then again. it does depend on your shocks also.. I've
got stock shocks with about 3inch lowered springs... :D
Looks aight... just ask Ryan about the ride..
Bump and Grind all the way baby!!
I've got 255/40 on the rear and 235/45 on the front with JIC coilovers... These coilovers are sssoooooo stiff!!!!! Lets just say they are the equivalent of an iron bar in place of the coilovers... When i jack up the car, the coilovers only push out less than 1cm... So i find the ride very harsh, but awesome round corners, feels like its on rails!!! And around the track is awesome as well...
As for diff bounce, i got a 2 way nismo LSD, and i don't notice any sorta bouncing, just wheel spin...
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe will give me my power goals and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
