HI guys, great forums here!
I have just bought a '93 R33 GTS-T, and want to replace the skinny stock tyres on it with some decent rubber.
I am considering 235/45 on 17s at the front (on 8" rims), and 255/40 on 17s at the rear (on 9" rims).
My two biggest concerns are that if I go with the general consensus and 235/45/R17 on the front and 255/40/R17 on the rear I will
A) get a pretty harsh ride and
B) Get into grief trying to do a hard launch or powerslide with 'diff bounce' (not the right term, but all I can think of now).
At the moment the stock tyres allow me to do fantastic, smooth powerslides and launches without the wheels bouncing up and down like crazy and costing me time (and perhaps killing the diff)... what is the likelehood of having that problem with 255/40's on the rear?
If it occurs, do I need to go to a higher profile/skinnier tyre to avoid it, or buy better shocks, or is it as the guys at BobJane suggested down the the choice of tyre (not size)?
What do the drifters use on these things, these sort of tyre setup? I dont plan to drift, but certainly want to be able to step it sideways or do a serious launch.
Any help would be appreciated! Thanks
Conrad
I have exactly the tyre/wheel sizes that you want to upgrade to, and I only have 2 problems - 1 is the guards are too narrow on the front, I need to get them rolled or something (or buy GTR guards :D) and 2 the rear tyres are so soft they shred and leave black tyre dust all over the back of my car. Well that's not related to the size at all but I thought I'd mention it anyway :D
I don't have any problems with comfort, handling or traction with this setup. I'd say a lot of that would have to do with your shock absorbers and sway bars anyway.
Hi JimX,
thanks for the update - do you run stock suspension on yours? mine is totally stock at the moment, so trying to get a feel for if I will need to move to better shocks once I have this tyre setup on.
Hmm... if theres no probs with the sizes I have picked, now I just have to pick WHAT tyres to use... sheesh!
I do like the look of the Falken 451's, if you have any advice on tyres I am listening :D
I've got Bilstein shocks in mine. It did have the factory suspension when I got it but it was totally worn out so I can't really compare the ride qualities. The steering wheel would shudder like a bastard everytime I hit a decent bump with both front wheels at the same time.
I've heard that the Japanese sports suspension (Cusco/JIC/Tein etc) are all really hard and not very comfortable for Australian roads. And unless the road is really smooth you'll be airborne a lot of the time anyway with ultra-hard suspension. I was originally after Koni adjustables but apparently they don't do a kit for Skylines yet.
For tyres I would probably go Nankang, that's what I have on the front and they seem to be a bit harder than my rear Toyo's (much less tyre dust) but seem to grip just as good. When my rears wear out I'll try Nankangs on the back too. I don't know much about Falkens because they have so many different models, but I do know that the low-end hard model that most people put on their Skylines to compliance them are pretty crap. Go for something a bit softer.
Check out this thread on tyres
Tyres
I have the 25540s on the back, and 23540s on the front, its an awesome setup, and doesnt ride harsh at all, with the purchase of my new tyres i'll have a similar setup.. try and keep the profile the same.. is there any reason you want 45s on the front and 40s on the rear?
235/45 is a closer match in height to 255/40 than 235/40 to 255/40. Here's what the profile height of each of the aforementioned will be:
235/40: 94
235/45: 105.75
255/40: 102
255/45: 114.75
So if you kept the same 40 profile front to rear, the rear tyre diameter is 8mm bigger than the front as opposed to about 4mm smaller if you got 45 for the front. I guess it's not much difference either way, but for that reason it's fine do choose either profile combination.
Personally I would get whatever size made the speedo most accurate (ie closest to stock) and then get the profile on the front that was the closest in size to the rear.
The reason why i say it would be a little bit harsher would be
the less flex in the tyre wall on a lower profile tyre.
Does everyone agree or disagree with my theory/practise?
Hmm. but then again. it does depend on your shocks also.. I've
got stock shocks with about 3inch lowered springs... :D
Looks aight... just ask Ryan about the ride..
Bump and Grind all the way baby!!
I've got 255/40 on the rear and 235/45 on the front with JIC coilovers... These coilovers are sssoooooo stiff!!!!! Lets just say they are the equivalent of an iron bar in place of the coilovers... When i jack up the car, the coilovers only push out less than 1cm... So i find the ride very harsh, but awesome round corners, feels like its on rails!!! And around the track is awesome as well...
As for diff bounce, i got a 2 way nismo LSD, and i don't notice any sorta bouncing, just wheel spin...
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
