Hi,
my r33 gts-t came with a turbo timer when I bought it. I was told its an apexi. It is a silver thing, blue light in the screen and 4 buttons, two on each side of the screen.
the timer has three modes that I can work out.
1st - override, press the button and the car shuts off immediately
2nd - manual timer (I have set it to 1min and it counts down from there)
3rd - (which I havn't used) is the automatic mode, the car has a temp sensor in the top radiator hose and it runs until it is at a predetermined temp and shuts off.
The car is always in the manual timer mode (except for a couple of times when I have shut it off with the override when necessary.
Now this fault ahs happened twice, interestingly both were after giving it a bit of a run (not a thrash at all but having wound a gear or two out within the last 5 or so minutes)
the key is turned to off and instead of the turbo timer counting down it beeps loudly, the engine shuts off and the timer screen say 'PEFrr'
any ideas or experiences?
to check if its wired in
leave the car running in neutral
put on handbrake
turn the key off
let the timer start to count down
drop the handbrake during count down
if its wired in the engine should shut off
