What Other Sort Of Wheels Will Fit A Skyline (magna, Commodore)?
Hey guys,
Most people have seen my forsale tread and i have recieved a lot of interest. I'm looking at purchasing a set of stock wheels, can even be off a commodore, magna providing they fit.
Does anyone know what wheels will fit my R33 turbo?
If anyone has something around- doesn't need to be rwc (AS LONG AS THE CAR CAN STAND), i happy to discuss an arrangement with you.
Peter
0411 588 669
off the top of my head
toyota, mitsubishi, honda ford ,porsche..I beleive mostly use this stud pattern...hondas and new lancers use different offsets though. usually around +45-50...and sometimes centre may need to be drilled out..
how much u want to spend, i have some r32 rims with bridgestones, with decent tread on them...Paid 300 for them but never used them...
Edited by Arthur T3
Hi,
I might be interested. How much are you selling?
Do you have pics and what size tyres have you got on the r32s?
New to forum, can't PM yet so you can email me at [email protected]
Thanks,
Jon
ive got r34 gt stockies in black tyres arnt the best
pm me if u interested
Hi,
I might be interested. Was the black coat sprayed on? How much are you selling?
Do you have pics and what size tyres have you got on the r34s?
Thanks,
Jon
I have stock r34 rims also but not in very good condition. The paint has worn off on the centre of the rims, and 2 of the tyres have low tread, I'd say 40-55%, the other 2 have 70-80% tread left. Mine are 16 inch
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
