You need a retune to make use.
Just changing fuel will not realise the full benefits.
There is extra timing and fuel mappings that need changes to see the gains that are to be had.
That's what I thought, but is there any danger?
ie due to the ethanol content not flowing enough fuel on the PULP98 tune? Or is 10% ethanol not enough to drastically change the flow requirements?
Should be ok, I tried it a while back for its higher octane but I found little difference in knock protection between that and BP98. If you want benefits re-tune for E85, more pumps should become available very soon.
No worries. Yeah i plan on getting a netbook to plug into the Haltech and tuning a map for E85 so i can switch between the two as need arises... Just dropped $10k+ on the car though so perhaps i'll leave it a while.. ;)
Well not overtly major other than the "why?" ;)
Just use as is until you are tuned for it.
Well not overtly major other than the "why?" :down:
I just happened to be at the airport and needed some petty. United had E10/100 and as i'm not sure what their 98 is like i thought i'd chuck half a tank in.
Just wanted to make sure it wasn't going to break anything :blink:
i use E10/100 ron and i certainly rate it. its about 1.20 a L most days and ive tuned my car to suit the fuel. awesome torque gains from few degrees extra timing.
Would tuning for it be that easy - just bung in another couple degrees and run it up on the dyno to make sure it's still not near detonation?
after all the dollars you spent on a custom tune I would just run 98. I would only run the E10/100 ron fuel if you took it back for a quick retune.
I tried the E10/100 ron fuel a while ago and I got 5L/100km worse fuel economy for no gain in power (because I didnt get a tune). So I quickly changed back to 98.
Just wait for E85 and get a custom tune done then.
Edited by Harey
Aight :blink:
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
