Hey all,
After an awesome response in the previous thread a few of us are keen to donate blood or plasma.
I have checked with the Blood Bank in Southbank and on the 23rd of June there is at least 10 places for blood donations between 5.55 and 7pm, and at least 4 spots for Plasma in the same time. If you haven't donated before you will need to do whole blood for your first time.
Now these times might not be available come a few days so if we can vote asap then we can lock in a date and start booking.
You will need to call 13 14 95 and book yourself in as you will either need your donor ID or to answer a few questions if you are new. If you can get there for an earlier time please book it as some people might not be able to get there as early as others.
Any questions let me know!
6-7pm (approx)
Wednesday 23rd June
Blood Bank:
Southbank Donor Centre
Level 1, 51-65 Clarke StreetSouthbank 3006 Victoria
Clicky for gmaps, be careful google mapping the Blood Bank on its own as it takes you to the old one in Kavanagh street!
8pm (approx)
Dinner:
Garage Cafe & Bar
221/221 Berkeley StCarlton VIC 3053
Clicky for gmaps
Current attendee list:
Cha_Chaos
JamesK
vspecIInur
Admaz
Basti
AGE
turbo x-trail (by correspondance)
At least 3 of my mates from motorcycle riding
HEKT1K
fasthally (maybe?)
Jinkz
Astro Boy
xALmoN
  • Replies 51
Dinner will be after as most people will be heading to the bb straight after work.
Basti don't book until we confirm what day we're going on! Unless you can't go on one of the days and want to go whether it's with us or not :)
Actually I just remembered I have Japanese on Tuesday night lol!
But if you can only go Tues, still go! I'll be in the city anyway and if there's a group can do something both nights :)
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
