  • Replies 54
What is regarded as the best exhaust at the moment? I am looking for...
* Something made out of titanium (to save weight)
* Something that is legal (or close to it :P )
* Something that will not harm -- or hopefully -- will improve response.
Also, has anyone tried one of the Apexi hi-flow 3" cats?
LW.
meggala, good to hear you got such good results from the turbo and glad the thread was of help. Pretty responsive little package you have there - I wonder what the advocates of never using bush bearing turbos would say to your results?
two people that just dont get it then.... your gunna kill your cars...
so it would follow that my car shouldnt be running.
where do you get your info from? heresay, or actual experience? I can understand concern for someone who may damage their car, but dude, give it a rest - your not their mother.
I had no probs at all running on base map in summer. when it made it to the dyno it was rich everywhere.
but anyway, thats a bit off subject
thanks steve, hey lwells. the n1 or the duel n1s are the best review and results at the moment. so if your in for something to the specs below i would go the n1. :wassup:
LW.
You mean the Apexi N1? What about the Ti HKS's?
Has anyone actual done a comparison of the various titanium exhausts lately?
Edit: I should have added, it has to be turbo-back for R32 GT-R
LW.
I have never taken my car down the 1/4, when I drive hard, I like it to last a bit longer than a few seconds. It is a daily driver. Not huge on cruises, prefer to go for drives with smaller groups. Cruises tend to attract too much attention and end up stuck behind guys who may not be too interested in a spirited drive.
BTW DJ, are you going to answer my questions?
What about these units?
http://www.fujitsubo.co.jp/search/prod-v.p...cnamID=00000520
Edit: Whoops, wrong link. Fixed now.
LW.
LW - That's the exect same exhaust I have - It seems to go well.
330 rwkw @21 PSI - HKS 3040 - similar setup to steve. Boost starts at 3000 RPM and I have it all at 4100 RPM.
Can I ask where you got it and how much you payed? (PM me if you don't want to post)
Cheers,
LW.
LW,
Did you follow the links I posted back here, about the HKS Ti Drag system ?
It works a treat, but it's different from the other HKS Ti systems, many of them only have a Ti ail pipe.
Yup, was rather impressive. Just trying to way it up against other titanium systems.
LW.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
