Hello guys
Just last week I wrecked my ECR33 drifting at the track.......... fast forward a few days and I have a new HR33 with my old engine set.
the only difference I see is the small junction box above the ecu location on the HR33 only has one spot for the big plug and that's it. The small clip next to it reminds me of the body wiring loom for the s13.. this was blank as well when removing the HR33 engine harness.. I cut the small clip that fits into that location on the HR33 off of the ECR33.... If its similar to the s13/14... that is just for your gauge cluster.
basically my injectors which worked before the swap are not clicking when cranking or turning CAS by hand. I have not check spark yet as it was getting late and had to go to work in 3 hours. I am getting plenty fuel. Ill try another CAS after work.
anyone done this swap and if so what were any issues if any?
ps
running PFC not issues at all after the crash.
https://www.sau.com.au/forums/topic/323725-rb25det-into-hr33/
there was nothing to patch. swapped the entire engine with harness over and every plug was plugged up. engine ran fine before the swap. the only thing disconnected are the grounds and power source amongst the obvious things to remove the engine.
no spark at all.
I used 3 CAS, 1 set of coil packs and 3 ignitors today.
been reading up on possible relay issues.... I directly powered and grounded the relay still nothing. Ill figure something out... events are coming up fast.
So your engine and loom is from a series 1 but is the donor a series 1 or 2? The power feed for the injectors is different and the series 2 doesn't have relay to switch the coils on like the series 1. The power feed to the switching side of the relay is missing in the series 2 loom.
Edited by BH_SLO32
no sir my engine is a S1. I fixed the issue about 2 hours ago
I had to power the injectors and cut the thick white wire on the relay next to the ecu and hook power up to the other wire not connected to the relay.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
