hi for sale late 1995 r33 gtr v spec brembro brakes etc standard
colour black
km 101000
con very good
body mods has
full veil side body kit
18 by 9.5 star corp racing wheels
nismo rear spolier
tinted windows
drive train
exceddy hyper sensitive button clutch
dba 2 piece 8000 series front rotors with gold hubs
tein coil overs have standards as well
bolt on wheel spacers so wheels will clear brakes
engine mods
oramni built rb26 from the nismo factory
has new 50 mm alloy radiator
full 3 inch exhaust with quality front pipe
new gtr n1 steel wheel turbos
new intercooler
big injectors
after market fuel pressure reg
largest in tank walbro fuel pump
custom made oil catch can
twin pod filter setup with air flow meters removed
haltech full ecu with map sensor
alloy fly wheel
interior
pillar pod with greddy guages
centre pod with greddy guages boost oil temp water temp oil pressure
full auto touch screen dvd player
twin fusion subs in rear with fusion amp
after market speakers and tweaters
trust gear knob
greddy electronic boost controler
turbo timer
after market gear boots
genuine floor mats front and rear
car is a real head turner
in very good con in and out
have a dyno sheet for 332 kw at wheels car is currently running 290 kw for street use
NO TYRE KICKERS GENUINE ENQUIRIES ONLY
29 000 ONO WILL CONSIDER SWAPS FOR RIGHT CAR PLUS CASH
https://www.sau.com.au/forums/topic/323737-r33-gtr-vspec-with-mods/
colour black
km 101000
con very good
body mods has
nismo rear spolier
tinted windows
drive train
engine mods
new intercooler
big injectors
alloy fly wheel
interior
trust gear knob
turbo timer
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
    • From my own first hand experience, keeping power for a fun Street able skyline down at a responsive low 200 wheel KW, is the best. It makes it super drive able through the twisties, you're not just smashing mass wheel spin, or only able to open the throttle for a split second before being at absurd speeds. That said, plenty of people like being morons at more than double the speed limit on public roads and hence are happy with 600whp and seeing 200kmh fly up frequently and fast. Also, at that low 200, a GTR can still do a decent quarter mile, and with a bit of fancy  clutch work (foot, not the parts) can still beat many many cars in a traffic light gp, even in the wet.
