Hi All,
I am looking for someone to join our 6 Hour team for the August event. It involves 2 days at Phillip Island doing lots of laps for very relatively small outlay. Car only needs to comply with similar regs for sprints and can be run on a basic CAMS license.
Would love to have another SAU member there to enjoy the fun. Just PM or phone me if you are interested.
Chris.
0417530116
https://www.sau.com.au/forums/topic/323747-phillip-island-6-hour-regularity/
Hi All,
Chris.
0417530116
Hi, will call you to discuss further. BTW what car are you entering the 6 hrs?
Alex 0433 878905
www.jds-auto-imports.com
Mordialloc 3195
ill be down in a white or a black r32 gtr
see you there say hello
im the fat f**ker in the funny hat
Hi, Just emailed Chris with my intention to join his team with my S15. Read the sub Reg that the minimum lap time ( 1:55) the quickest you are caped,going under that, you will cop penalty and even disqualified.look forward seeing you there.
Bump!
Only 1 spot left. Someone must want to stretch the legs of a GTT. No need to thrash it but heaps of laps to be had as fast as you feel comfortable with.
Go on, you know you want to :P
Will call you tomorrow,or call me on 0433878905. I have got my mate interested to join with his GTR33
Just to give anyone thinking about it a bit of a stir along. I am in the same team as Fatz, if anyone wants to get into the event this year your ONLY way in is with a team that needs another driver. Our entry was in on the Thursday of the week entries opened and we are team 47 our of 50! There are no team entries left and a reserve list of teams as well.
Most reasonably quick cars were doing somewhere between 2:00 and 2:15 last year, with up to 50 cars out there at once your times get knocked around a fair bit, plus it will almost cretainly rain, it is the Island after all!
Edited by Blue
Sorry to say that our team has a full compliment of drivers although I am happy to have a reserve name in case of emergency.
I agree with Blue. We are team 48! Which means we must have had our entry in 18 seconds after theirs :-)
Seeing Chris in your first post and looking at the entry list I should say who I am (Not putting full names up online of course) It is Paul with the yellow R31 Coupe, Cookie and I will see you at the island! Unless of course you are not the Chris I am thinking of! No matter seeing we will be in adjoining garages, we will see you anyway!
I reckon entries will need to be in with the promoters by the Wednesday in the openeing week next year to avoid missing out!
I had already guessed it was you or Cookie. Is the yellow peril going to survive this year? :-)
It should!
The problem last year was caused by a port that I had welded up in the plenum, the welder did not do a good enough job of it and a blob of alloy broke free on the back of the weld and went into #4. A head gasket and both manifold gaskets to pull the head off to retrieve it and it was back up and running a week later! I had initially thought it had broken a valve spring as it rattled and dropped a cylinder. A shard of alloy was keeping an exhaust valve open and the main bit was squashed flat between the head and piston.
Here is hoping for a trouble free run this year.
Hi,
Paid up for the entry fee, My mate just came back from US and very interested to enter his GTR33 with a team who requires one. Please let me know if any team needs a car and driver to join.
Also seriously looking at doing Bathuurst drive/sprint or endurance/regularity this year.Any one need a car/driver to join???
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
