Just trying to tidy up my cupboard/garage. Bunch of random things here and there. I'll try to add pictures to most things, the other things are fairly self explanatory so won't bother but if you really want pictures let me know.
All prices don't include freight so add that ontop of it. Send me your postcode and i'll try to give a rough freight charge.
Righteo here we go:
My old RB25 covers. Both cam covers and valley cover. Painted in Lamborghini Blue Pearl Metallic (I have the paint code if you want to repaint some of it). Also features a RB25 badge in the centre.
Pretty good condition, some of the paint is a bit scratched/chipped off. Probably would be due for a repaint if you were picky, if not they still look pretty decent. Also has both right angle fittings in the covers (from factory the right one is a three way fitting).
Here's what they looked like on the car.
Chasing $80 for them.
Series 1 front indcators. Perfect condition, no cracks or damage. Could pass them off as new.
Chasing $20 for them.
This is an attatchment trumpet for the older type Blitz BOV's. Changes the noise of the BOV.
Chasing $10 for it.
A Swedish DLS 12" W312B 150WRMS (250W peak) sub. Original RRP was $249 (still has sticker on it). Nice crisp European sound to it. Was used for a short period of time (few months) but no longer wanted a subwoofer in the boot. Basically new.
Chasing $70 for it.
Also have a protective DLS grill for it for an extra $10 if you want. Will take picture if you require.
Stock RB25 exhaust manifold heatshield painted in flameproof silver paint. Good for people that no longer have one on their car and want to get underbonnet temperatures down or to cover up the ugly looking rusted stock manifold.
Chasing $20 for it.
Stock RB25 turbocharger oil and water fittings including oil return.
Chasing $10 for them.
Stock RB25 plenum that has been bead blasted to new condition. Perfect for some one wanting to polish up the plenum and simply swapping it over once it is done. Note the plenum has been cut out from another photo with a bunch of different parts that I sold ages ago, hence the funny cutting around the picture.
Chasing $30 for it.
Full 5 piece set of factory R33 Series II floormats. Good condition, rear is practically brand new since I didn't like having rear passengers. Will take photo if needed.
Chasing $60 for them.
Stock R33 RB25 oil cap and radiator cap.
Chasing $5 each.
Also have a bunch of alarms if some one is interested i'll post them up with pictures. Price range from $50-$200.
That's all I can think of at the moment, i'll probably add some more stuff later.
Cheers
Phil
Edited by PM-R33
https://www.sau.com.au/forums/topic/323762-garage-sale-bunch-of-random-parts/
interested in the exhaust heat shield. Did you have the bolts to hold the shield on? If so I'll take it & postage to 4711.
Cheers
Jared.
Umm I might still have them, ill have a look. If not they are just normal little bolts, I actually replaced mine with stainless steel allen key ones so they wouldn't rust. Anyway I'll let you know if I have the old bolts and I'll throw them in. Ill find out postage cost and get back to you.
Cheers.
Cheers.
Its fine if you only had 1 bolt, I'll just run down to Bolt & Steel and match a set of newy's.
Thanks.
All PM's have been replied to.
RB25 covers have been sold.
Still a few things remaining; would love to see them gone so I can get some more storage space.
Righteo here we go:
Chasing $10 for it.
Chasing $70 for it.
Chasing $20 for it.
Chasing $30 for it.
Chasing $5 each.
Cheers
Phil
hey mate do u have a remote start alarm???
  • 1 month later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
