Hey
Lately my oil pressure gauge has been getting pretty low from time to time and other times it will be normal and fine, sometimes it even drops down so low and then goes back to normal during a 1 hour trip.
I have a photo of the pressure gauge at its lowest which was only 2 days ago, and since it hasn't had the issue but it does come and go and im not sure if I should be worried or not, any opinions or suggestions would be helpful.
https://www.sau.com.au/forums/topic/323782-r34-oil-pressure-low/
common problem for the fuel pressure sender/switch to play up, replace that and you should find that your reading will return to what it should be.
its located near the oil filter
ive circled the oil pressure sender in red in the pic below
if that fails then it looks like ur oil pump is quite worn..
Hey
Have you checked your oil lately..??
not milky..???
I have this exact same problem with my R34 GTT ... I reckon its a faulty sender unit. I asked Nissan how much for a new one and from memory it was close to $200 yikes :P
but it's been bugging me for so long now I might just try get one from the wreckers just to see if its the actual sender unit (provided I don't get another lemon from the wreckers)
How hard is it to remove/replace one of these sender units through the engine bay ? would be a real pain in the bum hey ? the whole thing that you circled in red has to be unscrewed yes ? would oil leak out when you unscrew it?
  • 1 year later...
  • 5 months later...
Hey
my r34 GT has the same thing, when its cold it sits about 5 ish and when its warm and just idle it will sit around 1 ish but will go up when you start to drive ??
freaked me out as well when i first seen it , so is this anything to worry about ? thanks guyz
That's normal. The hotter the engine is, the more oil will thin out resulting in less oil pressure. So on a cold start oil pressure will be very high. On operating temp it'll probably be around a quater of what the pressure is on cold start.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
