Hi guys...looking at getting a greddy emanage ultimate installed on my AUTO...r33 gtst. I know most tuners like efi, apc, 999, pits etc.. have speicalise in particular brands of ecu's, and I would just would like some help in deciding which tuner to pick that does good work with the greddy ecu's around south east QLD (either coast, brisbane etc).
Cheers
https://www.sau.com.au/forums/topic/323826-tuners-for-emanage-ulitmate/
Pits wont.
I sold mine a few years ago in favour for the PFC, just so much easier.
Its a shame you cant use a PFC :D
PFC arnt all that man, ill rate emanage. keeps stock ecu cold start settings etc. MINT !!! piggy back
hitup STZ fo sure.
im in the middle of getting an emanage myself :domokun:
Thanks for the help everyone!!! STZ sound pretty good for the emanage and anymore info....KEEP IT COMING LOL......
finally a bit off topic, but has anyone got info on whether or not a z23 vg30dett AUTO ecu, will work as a replacement for the ecr33 auto ecu??? because if that was the case i could also concider a nistune for my ecu option aswell.....
I had an emanage ultimate for a year or 2.
seemed to have loads of problems, so I got rid of it and went for a nistune -more reliable, cheaper, more choice of tuners, etc.
i like the idea of the emanage, but i dont think they work so well with 34's
now very happy with Nistune
Yeah believe me, if i can find out if i can get the z32 auto ecu, to work as a replacement for the ecr33 ill be getting a nistune no worries lol....
talk to EFI Performance. Sean has worked with nistune for ages. nice guys, very helpful.
Cheers pear,
yeah i had a few people on boost recommend EFI today aswell (for nistune), so im going to give them and nistune a call first thing tomorrow and see what they can do about my little ecu problem....
Sean at EFI said that shouldn't be any drama putting either r32 or z32 auto... ecu's in my car for a nistune, just that with the r32 ecu you will lose VCT, and with the z32 ecu they have to rewire for timing and injectors. Only effect on the auto transmission is a slight increase in lenght of the gear changes between 1st and 2nd. Also chasing an EMS Stinger ecu on here second hand ($600 without loom), but atleast i have a bit more of an idea on which way to go now... This has given me quite a bit to think about and thanks everyone for the help..much appreciated.
cheers...
good to hear
Finding an ECU you like is one thing, but finding a tuner you can trust AND one that can work with your preferred ECU can sometimes be hard!!
In hindsight, I should have picked my tuner 1st.
I know EFI do a lot more ECU's than Nistune, and in my books Sean is one of the best tuners I've seen.
ps. thanks tristan :domokun:
Ended up buying an EMS Stinger 4424 off a guy on Boostcruising...$650, which wasnt too bad. Keep the factory ecu (to control the auto) and wire the stinger in to control the rest. Means i dont have to swap factory ecu's and iv'e basically got a stand alone ecu, which i can use as a piggy back. I dont need a z32 afm either lol..so now i just need to get everything in the car and tuned....
post my results on dyno as soon as its all done...
cheers everyone for the input and if anyone has any more info that my help myself and or others with emanage tuners and tuners in general around southeast qld..keep it coming
thanks
brendan
  • 2 years later...
Hi ,
sorry to bring up an old thread but wanted info regarding this
Who can tune eManage Blue/Ultimate in Sydney? I am located near Hurstville.
Hey mate, This post is in the QLD section, so I would suggest you repost it in the NSW section you would get more responses there.
  • 2 years later...
obv a old thread but wondering if any updates on who tunes greddy emanage in Brisbane for current times did look for stz but no phone answering unsure if closed down or wrong number for current times if any1 could help be gr8
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
    • That is porn and I wish I could do it easily on my streeter.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
